Buy "chanellock" online - search for the best price - compare prices
Page (4 of 4)
1 2 3 4 |
Chanellock 9-1/2inch Straight Jaw Tongue and Groove Pliers - CHA420
17.89
17.89
Length: 9-1/2" - 240 mmAdjustments: 5Capacity: 1-1/2" - 38 mmSAFE-T-STOP prevents finger pinchDistinctive CHANNELLOCK BLUE comfort gripsPatented PermaLock fastener eliminates nut and bolt failures This is one of the most popular models, right angle teeth grip on all directions for maximum bite and minimum wear. Its patented undercut tongue and grove design assures, no slip jaw action. Also the reinforcing edge minimizes stress breakage. Made with the comfort and durability to last!. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9-1/2inch Tongue and Groove Plier, Code Blue - CHA420CB
28.59
28.59
Patented reinforcing edge minimizes stress breakagePatented PermaLock fastener eliminates nut and bolt failuresLaser-hardened teeth provide longer lifeGrips have a Santoprene core with TPR-rubber overmold which composites for durability, comfort, and secure gripNew Code Blue designation on handles makes it easier than ever to choose the right tool for the job9-1/2" tongue and groove plier, Code Blue.? Channellock uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? This has a unique design, right angle teeth grip in all directions for maximum bite and minimum wear.? Its patented undercut tongue and groove design assures no slip jaw action. Also the handles are red and blue and have a designation code on the grips, makes for easy identification. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9-1/2inch Tongue and Groove Utility Pliers - CHAGL10
13.29
13.29
Ergonomically designed offset head for greater leverageSpecial jaw design accommodates many shapesPermaLock Fastener eliminates nut and bolt failureCHANNELLOCK BLUE comfort gripsLength: 9-1/2"-240mmAdjustments: 5Capacity: 1-1/4"-32mmThis bright CHANNELLOCK BLUE Gripped tool is standard equipment in the tool belts, buckets and tool boxes of professional electricians, plumbers and mechanics all over the world. This is quality they know they can count on because any tool with CHANNELLOCK on it is made to the highest standards.? Built to last!. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9-1/2inch Tongue and Groove V- Jaw Pliers - CHA422
17.39
17.39
Right angle teeth grip in all directionsUndercut tongue and groove, won? t slipPermaLock Fastener, eliminates nut and bolt failureReinforcing edge that minimizes stress breakageCHANNELLOCK BLUE comfort grips CHANNELLOCK uses high carbon C1080 steel for superior performance on the job, and an electric coating for ultimate rust prevention.? There was no sacrifice made, these have comfort and durability needed to last! Length: 9 1/2" - 240mm; Adjustments: 5; Capacity: 1-1/2" - 38mm. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9.5in,Tongue & Groove Plier,with Handle Stop - CHA421CB
34.59
34.59
Patented Safe-T-Stop feature prevents finger pinchLower jaw combines with expanded reinforcing rib to prevent handles from contacting each otherPatented reinforcing edge minimizes stress breakageUndercut tongue and groove design won't slipRight angle, laser-heat treated teeth grip better and last longer Channel lock pliers are made of high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? This has a unique design, with its SAFE-T-STOP, the lower jaw combines with expanded reinforcing rib to prevent handles from contacting each other. Also the right angle teeth grip in all directions for maximum bite and minimum wear. PermaLock fastener eliminates nut and bolt failure. CHANNELLOCK BLUE grips for comfort. There's no sacrifice here, you have the durability and the comfort!. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9.5inch Cable Cutter - CHA911CB
40.89
40.89
Cuts up to 4/0 aluminum and 2/0 soft copperHeavy-duty design, precision made of fine polished high carbon drop forged steelGrips have a Santoprene? core with TPR-rubber overmold which composites for durability, comfort, and secure gripNew Code Blue designation on handles makes it easier than ever to choose the right tool for the job Channellock uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? This has a unique design, heavy-duty and carefully balanced with broader handles for better leverage and extra comfort.? Also the closely matted cutters are scientifically heat treated to hold their edge.? All in one durability and comfort! It's an all in one tool that is easy to store. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9inch Crimping Plier with Cutter - CHA909CB
28.89
28.89
Precision made of fine polished high carbon drop-forged steelPerfectly mated cutters, scientifically heat treated to hold their edgeGrips have a Santoprene core with TPR-rubber overmold which composites for durability, comfort, and secure gripNew Code Blue? designation on handles makes it easier than ever to choose the right tool for the job. 9" crimping plier with cutter. Channellock pliers are made of high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? There's no sacrifice here, you have the durability and the comfort!? This is a two in one, precision crimping dies and cutters.? It's designed for crimping both insulated and non-insulated solder-less connections and terminals on 10 to 22 AWG wire.? The slim nose allows working in a confined area an ease. Also there's no sacrifice here, you have the durability and the comfort!. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Chanellock 9inch Hi-Leverage, Round Nose Lineman Plier - CHA369CB
48.19
48.19
? ? New Code Blue pliersSantoprene and TPR, dual compound grips in bold red and Channel lock Blue are more comfortable and durableLetter codes on each handle provide the quick tool recognition needed for any proChannel lock Permalock fasteners eliminate traditional nut-and-bolt failureLaserheat treated cutting edges and teeth cut cleaner and grip better while providing long lifeMade in the U.S.A. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9inch Hi-Leverage, Round Nose, Lineman Plier - CHA369CRB
37.99
37.99
New Code Blue pliersSantoprene and TPR, dual compound grips in bold red and Channellock Blue are more comfortable and durableLetter codes on each handle provide the quick tool recognition needed for any proChannellock Permalock fasteners eliminate traditional nut-and-bolt failureLaserheat treated cutting edges and teeth cut cleaner and grip better while providing long lifeMade in the U.S.A. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9inch Linemans Premium Wiremaster Pliers - CHA349
53.29
53.29
Perfectly mated cutters, scientifically heat treated to hold its edgeEnclosed-joint design holds cutters in perfect alignment for the life of the plierSpecial high leverage handle designRound nose designHeavy duty construction Channellock uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? Most of the manufactures use two sharp edges which can eventually become misaligned, losing there cutting effectiveness over time.? Channellock's knife and anvil ensure proper cutting edge alignment resulting in a clean cut every time!? Also this is to ensure perfect mating and superior cutting edge life.? The laser heat-treated cutting edges last 3 times longer!? It's not only made for durability, but for comfort as well, with the blue grip handles. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9inch Linemans Round Nose High Leverage Pliers - CHA369
30.89
30.89
Perfectly mated cutter, heat treated to hold its edgePolished high carbon drop forged steelUseful crushing areaCHANNELLOCK BLUE comfort gripsLength: 9"-225mm Channellock uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention. Most of the manufactures use two sharp edges which can eventually become misaligned, losing there cutting effectiveness over time.? Channellock's knife and anvil ensure proper cutting edge alignment resulting in a clean cut every time!? Also this is to ensure perfect mating and superior cutting edge life.? The laser heat-treated cutting edges last 3 times longer! Not only made for durability but for comfort as well, with the blue grip handles. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock 9INIRONWORKERS - CHA351S
45.89
45.89
Chanellock Cable Cutters - CHA911
30.79
30.79
Cuts up to 4/0 aluminum and 2/0 soft copperHeavy-duty design, precision made of fine polished high carbon drop forged steelChannellock Blue handle grips Channellock uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? This has a unique design, heavy-duty and carefully balanced with broader handles for better leverage and extra comfort.? Also the closely matted cutters are scientifically heat treated to hold their edge.? All in one durability and comfort!. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock Crimping Tool With Cutter - CHA909
26.29
26.29
Precision made of fine polished high carbon drop-forged steelPerfectly mated cutters, scientifically heat treated to hold their edgeCHANNELLOCK BLUE comfort grip handles Channellock pliers are made of high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? There's no sacrifice here, you have the durability and the comfort!? This is a two in one, precision crimping dies and cutters.? It's designed for crimping both insulated and non-insulated solder-less connections and terminals on 10 to 22 AWG wire.? The slim nose allows working in a confined area an ease. Also there's no sacrifice here, you have the durability and the comfort! ? . Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Chanellock LINEMANS PLIERS - CHA3047
35.49
35.49
Perfectly matted cutter, heat treated to hold its edgePrecision made of fine polished, high carbon drop forged steelPerfectly mated cutters, scientifically heat treated to hold their edgeDistinctive Channellock Blue comfort gripsLength: 7-1/2"--190mm without side cutter Channellock's snipe nose pliers are made of high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? There's no sacrifice here, you have the durability and the comfort!? . Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock PLIERS LINEMANS - CHA350S
40.19
40.19
Perfectly mated cutters, scientifically heat treated to hold its edgeEnclosed-joint design holds cutters in perfect alignment for the life of the plierSpecial high leverage handle designRound nose designHeavy duty construction Channel lock uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention.? Most of the manufactures use two sharp edges which can eventually become misaligned, losing there cutting effectiveness over time.? Channel lock's knife and anvil ensure proper cutting edge alignment resulting in a clean cut every time!? Also this is to ensure perfect mating and superior cutting edge life.? The laser heat-treated cutting edges last 3 times longer!? It's not only made for durability, but for comfort as well, with the blue grip handles. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock PLIERS TONGUE A - CHA432
23.19
23.19
Made with high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust preventionAll included in a roll-up kit bag To a tradesman, having the right tool at his side is as important as his training or experience.? CHANNELLOCk pliers are made of high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention. This set includes each of the following: CHA430, CHA420 Tongue and Groove plier; CHA337 Cutting plier, CHA3017 Long Nose plier and CHA526 Slip Joint plier.? All made with the CHANNELLOCk BLUE comfort grips. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock PLIERS TONGUE A - CHA463
46.29
46.29
Right angle, laser heat treated teeth grip better and last longerPermalock fastener eliminates nut and bolt failureUndercut tongue and groove won't slipReinforcing edge minimizes stress breakageRight angle, laser heat treated teeth grip better and last longer CHANNELLOCK uses high carbon C1080 steel for superior performance on the job, and an electric coating for ultimate rust prevention.? CHANNELLOCK Blue grips for comfort. There was no sacrifice made, these have comfort and durability needed to last! These are Big as the job, Big as you need! Capacity: 4-1/4"; 108 mm. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock PLIERS TONGUE A - CHA483
84.99
84.99
SAFE-T-STOP prevents finger pinchPermalock fastener eliminates nut and bolt failureReinforcing edge minimizes stress breakageRight angle, laser heat treated teeth grip better and last longer CHANNELLOCK uses high carbon C1080 steel for superior performance on the job, and an electric coating for ultimate rust prevention.? There was no sacrifice made, these have comfort and durability needed to last! These are Big as the job, Big as you need!. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Chanellock The 6-in-1 Rescue Tool - CHA88
59.99
59.99
Tool Steel Punch - hardened tool steel punch easily shatters safety glassSpanner wrench - tightens and loosens hose couplingsGas shut off slot - shuts off gas safety valvesCutter - laser heat treated cutting edges cut through cables and wires quicklyGrabber - aggressive cross hatch teeth that twist, pull and grip easily. Also includes pry bar which quickly pries open windows and doors 26 ounces of window-punching, valve-twisting, wire-cutting, life saving power in your hand. One rescue tool that is small enough to slip into your pocket. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Chanellock WIRING PLIER 8 - CHA318WS
46.39
46.39
Letter codes on each handle provide the quick tool recognition needed for any professionalChannellock Permalock fasteners eliminate traditional nut-and-bolt failure or looseningLaser heat treated cutting edges and teeth are cut cleaner and grip better while providing long lifeMade in the U.S.A. New Code Blue pliers from Channellock Santoprene and TPR dual compound grips in bold red and Channellock Blue are more comfortable and durable. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Page (4 of 4)
1 2 3 4 |
