Buy "central tools" online - search for the best price - compare prices
Page (2 of 3)
1 2 3 |
Central Tools 3 Piece Outside Micrometer Set - CEN3M113
99.89
99.89
Forged steel constructionHardened carbide tipped anvil and spindleSpindle lever locksSmooth friction turn knobsAccurate to .0001 Includes: This is a 3 piece set, which the adjustment wrenches and spacers are included.? All packaged in a plastic blow-molded case for easy storage.? Includes: 3M101, 3M102 and 3M103. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 3-4in. .001in. Grad I Beam Frame Micrometer - CEN6071
179.03
179.03
Precision measurements to the thousandth and ten-thousandth of an inch require a quality micrometer. Central Tools manufactures many types of micrometers in inch and metric to meet all your measuring needs. Extra Hard Measuring Surfaces - Anvil and one-piece spindle are made of finest quality tool steel. Careful lapping on our own special machinery assures that faces are square and parallel. Simplified Zero Adjustment - Lets you reset your Central micrometer simply with the hex key provided. Friction Stop - Provides uniform pressure under all measuring conditions. I-Beam Frame - Designed to maintain dimensional stability. Powder-coated. Easy Reading Graduations - Machine spaced. All thousandths graduations are numbered so you can read directly without counting. Carbide Faces - On models with .0001 " graduations. Spindle Lock - Holds spindle securely for transferring measurements. Meets Federal Specs - GGG-C-105C on models with .0001 " graduations. Standards Included - On all micrometers above 1 " or 25mm. Range: 3-4" Grad: .001". Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 4 Piece Micrometer Set - CEN6151
604.69
604.69
Includes 1", 2", 3" and 4" outside micrometers I-beam frames designed to maintain dimensional stability Includes calibration standards Easy reading graduations: .001"Made in the U.S.A. Powder coated micrometers. Spindle lock holds spindle securely for transferring measurements. Friction stop provides uniform pressure. Includes CEN6009, CEN6031, CEN6051 and CEN6071. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 4-5in. .001in. Grad I Beam Frame Micrometer - CEN6091
188.83
188.83
Precision measurements to the thousandth and ten-thousandth of an inch require a quality micrometer. Central Tools manufactures many types of micrometers in inch and metric to meet all your measuring needs. Extra Hard Measuring Surfaces - Anvil and one-piece spindle are made of finest quality tool steel. Careful lapping on our own special machinery assures that faces are square and parallel. Simplified Zero Adjustment - Lets you reset your Central micrometer simply with the hex key provided. Friction Stop - Provides uniform pressure under all measuring conditions. I-Beam Frame - Designed to maintain dimensional stability. Powder-coated. Easy Reading Graduations - Machine spaced. All thousandths graduations are numbered so you can read directly without counting. Carbide Faces - On models with .0001 " graduations. Spindle Lock - Holds spindle securely for transferring measurements. Meets Federal Specs - GGG-C-105C on models with .0001 " graduations. Standards Included - On all micrometers above 1 " or 25mm. Range: 4-5in. Grad: .001in. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 6 Piece Import Outside Micrometer Set - CEN3M116
219.89
219.89
Includes 6 micrometers through 6"Graduated in .0001"Carbide measuring surfaces Custom wood case1 year warranty. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 6 Piece Outside Micrometer Set - CEN6171
914.16
914.16
Includes 6 micrometers ranging from 1" to 6".001 graduations Includes calibration standards Furnished in fitted plastic case Made in the U.S.A. Includes CEN6009, CEN6031, CEN6051, CEN6071, CEN6091 and CEN6111. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 6inch -20.65inch Electronic Digital Drum Gauge - CEN3B530
245.49
245.49
Graduations .0005"/.01mmEasy to read digital display with inch / metric conversionSelectable depth stops for easier usePointed anvils and 4.25" long arms to inspect drums before turning or replacingMeasure automotive and heavy duty drums Easy to read digital display with inch / metric conversion.? Selectable depth stops for easier use Pointed anvils and 4.25" long arms to inspect drums before turning or replacing.? Measure automotive and heavy duty drums. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Central Tools 6inch Flexible Pocket Rule - 1mm and 64ths - CEN6515
6.11
6.11
Top quality stainless steel, precision ground and tempered, clear etched graduationsPocket rules have spring pocket clipAvailable skin packed, one per card, or in ten packsGraduations: 64ths,1mm. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools 8inch O-Ring, Seal and Scribe with Hook End - CEN6543
6.09
6.09
One end sharp and tempered, other end hooked for removing "O" rings, seals, gaskets, etc.8" long with 90 degree bendBoth points hardenedSkin packed, one per card, or in ten packs. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Central Tools Angle Finder with Magnetic Base - CEN6494
15.59
15.59
Magnet in base holds tool in placeGraduated in 1/2" degree increments This is great for setting the front ends on trucks.? It measures the angle of the frame (pitch forward or backward).? With an easy to read scale.? Simple to use and handy to have. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Central Tools Brake Force Rotor Gage - CEN6459
503.09
503.09
Pointed anvils measure scored and non-scored surfaces Built-in depth rod to check brake pad and shoe wear Deep measuring arms 3.25"Fractional graduations: 0.001" Metric: 0.01mm This allows you to measure all brake rotors.? It has digital accuracy, which gives both inch and metric.? This comes packaged in a plastic blow-molded case for easy and safe storage. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Central LED Work Light - CEN100LED
183.80
183.80
Quick prep of panels for blending color and clearcoatingEasy prep for sail panel blendingUse anywhere a DA cannot reachQuick and easy prep for urethane bumpersUse to clean entire job and ensure all areas are properly prepped Final Sand is a fast cutting, long lasting, easy to use sanding paste which leaves a uniform fine scratch, removes road grime and rinses clean easily. Use to prep panels for blending and as an alternative to time consuming hand sanding.? Extremely fast cutting action.? Rinses clean easily and leaves no residue.? Sudsing action removes road grime while you sand.? Biodegradable and neutral pH. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Central Tools Depth Micrometer 0-6inch Range with 4inch Base - CEN3M646
179.29
179.29
4" base for stability, Fitted in plastic case 1 year warranty. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Dial Indicator Base - CEN6416
110.69
110.69
Securely mount your dial indicators on these magnetic basesPowerful, rugged, heavy duty magnets grip either flat or curved steel surfacesCan be used with any Central Dial IndicatorPowerful compact base, post, stepped rod and clamps2-3/8" x 1-7/8" x 2-1/2" Securely mount your dial indicators on these magnetic bases.? It's powerful, rugged, heavy duty magnets grip either flat or curved steel surfaces.? This is simple to use and keeps your dial indicator secure and safe. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Central Tools Dial Indicator Set with On/Off Magnetic Base - CEN3D102
109.94
109.94
A 0-1" dial indicator setComes packaged in a wooden box This instrument is used to accurately measure a small distance.? This set measures 0" to 1" in .001" graduations.? Comes with a on/off magnetic base with flex-arm.? This is very simple to use. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Digital Brake Gauge - CEN3M430
63.59
63.59
Includes storage case0 to 5 range3-1/4 reach Graduations - .001, .01mm. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Digital Tire Tread Depth Gauge - CEN3S401
35.00
35.00
Large digital displayReads in inch, metric and fractionalStainless steel construction Wide base for stability on wide treads 1" range for larger tire applications This digital tire tread depth gauge allows for quick and easy reading in inch, metric and fractional. The wide base and 1" long range is also good for larger vehicle tires. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Central Tools Digital Variable Temperature Heat Gun Kit - CEN3H202K
79.59
79.59
"Soft Touch" control for more exact temperature settingHigh and low settings each have 6 temperature settings (12 total)Total temperature range from 250 degrees F to 1200 degrees F.LED display clearly indicates level of settingPatented 80 second automatic cool air flow to prevent accidental burns and to extend life of heating element Comes with 4 tips in a plastic case. 1 year manufacturer warranty. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Central Tools Disc Rotor/Ball Joint Gage Set - CEN6450
272.19
272.19
Special locking pliers clamp securely to any convenient objectRange: 1"Graduations: .0011Reading: 0-100This checks ball joint wear and disc rotor run-out.? Also checks gear backlash, valve guide wear and camshaft wear.? With optional attachments checks tire and wheel run-out.? Eliminates vibration problems and false readings by mounting directly on spindle.? This set comes packaged in plastic blow-molded case. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Drum and Rotor Adapter Kit for Digital Caliper - CEN3K300
39.59
39.59
Allows caliper to convert to a rotor or drum measuring gageWill measure all brake rotors or drums up to 12"Includes set of clamps, set screws, Allen wrench, set of 3-3/4" contact points, set of 3/4" pointed contact points and set of 3/4" flat contact points in a plastic tube. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Drum and Rotor Adapter Kit Plus Caliper - CEN3K301
67.69
67.69
Allows Caliper to convert to a rotor or drum measuring gageWill measure all brake rotors or drums up to 12"Includes set of clamps, set screws, Allen wrench, set of 3-3/4" contact points, set of 3/4" pointed contact points and set of 3/4" flat contact points in a plastic tubeIncludes a Storm 3C301 digital caliper. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Dual Scale Dial Caliper - 0-6" 0-150Mm
253.95
253.95
Seperate inch and metric scales Dial indicator has fine line indicating hands Easy to read - black...
Central Tools Dual Temperature Heat Gun Kit - CEN3H201K
45.40
45.40
Three position slide switch for Off/Low/HighLow setting temperature is 850 degrees F.High setting temperature is 1120 degrees F.1 year warranty except heating elementKit includes 4 tips and plastic case. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Central Tools Face Type A - Dial Indicator - CEN4345
92.54
92.54
Range: 1.0 in. Graduations: .001 in.Continuous forward and reverse reading with revolution counterReading: 0-100Diameter: 2-1/4 in.Rack and pinion constructionLug back3/8 "diameter shank This is a face type A dial indicator that is also included in several of our popular test kits.? This particular one is separate, it's rack and pinion construction is very durable for a long life.?. Most Measuring Tools products are available for in-store pickup from Advance Auto Parts.
Central Tools Fluorescent Bulb for Central Stomp Lights - CEN11006-17
13.39
13.39
For CEN11001 and CEN11002 Heavy Hitter Lights. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Page (2 of 3)
1 2 3 |
