Buy "bwd select" online - search for the best price - compare prices
Page (2 of 5)
1 2 3 4 5 |
BWD Select Distributor Cap - C243
19.99
19.99
BWD SELECT caps are made of high-dielectric-strength, glass/mineral-reinforced polyester resin. The benefit is less carbon tracking and greater resistance. They also contain solid brass terminals for better connections. Most Distributor Components products are available for in-store pickup from Advance Auto Parts.
BWD Select Distributor Cap - C244
13.09
13.09
BWD distributor caps use glass-filled polyester resin with dielectric strength as high as 630 volts per mil to promote optimum performance. Most Distributor Components products are available for in-store pickup from Advance Auto Parts.
BWD Select Distributor Cap - C262
6.99
6.99
BWD Select Distributor Cap - C266
25.99
25.99
BWD Select Distributor Cap - C267
29.99
29.99
BWD Select Distributor Cap - C268
13.99
13.99
BWD Select Distributor Cap - C271
9.99
9.99
BWD Select Distributor Cap - C273
11.99
11.99
BWD Select Distributor Cap - C274
12.99
12.99
BWD Select Distributor Cap - C280
42.99
42.99
BWD Select Distributor Cap - C282
49.99
49.99
BWD SELECT caps are made of high-dielectric-strength, glass/mineral-reinforced polyester resin. The benefit is less carbon tracking and greater resistance. They also contain aluminum terminals for better connections. Most Distributor Components products are available for in-store pickup from Advance Auto Parts.
BWD Select Distributor Cap Cover - C185
13.99
13.99
BWD SELECT caps are made from high-dielectric-strength, glass/mineral-reinforced polyester resin and offer dielectric strength as high as 800V per mil, resulting in less carbon tracking, greater resistance to electrical breakdown and enhanced performance. Most Distributor Components products are available for in-store pickup from Advance Auto Parts.
BWD Select Distributor Rotor - D138
7.49
7.49
BWD rotors contain stainless-steel springs to match OE performance and feature durable phenolic plastic to promote a long working life. Most Distributor Components products are available for in-store pickup from Advance Auto Parts.
BWD Select Distributor Rotor - D147
5.99
5.99
BWD Select Distributor Rotor - D151
3.79
3.79
BWD Select Distributor Rotor - D152
5.69
5.69
BWD Select Distributor Rotor - D156
4.99
4.99
BWD SELECT rotors are made with high-grade-dielectric-strength alkyd material, resulting in resistance to dirt sticking and promoting reduced carbon tracking and a longer working life. They also contain solid brass segments for enhanced connectivity. Most Distributor Components products are available for in-store pickup from Advance Auto Parts.
BWD Select Distributor Rotor - D157
11.99
11.99
BWD Select Distributor Rotor - D158
7.99
7.99
BWD Select Distributor Rotor - D164
8.49
8.49
BWD Select Distributor Rotor - D166
5.99
5.99
BWD Select Distributor Rotor - D167
11.09
11.09
BWD Select Distributor Rotor - D168
5.49
5.49
BWD Select Distributor Rotor - D188
5.99
5.99
BWD Select Distributor Rotor - D189
7.99
7.99
Page (2 of 5)
1 2 3 4 5 |
