Buy "astro pnuematics" online - search for the best price - compare prices
Page (4 of 12)
1 2 3 4 5 6 7 8 |
Astro Pnuematics 3 Piece Dead Blow Ball Peen Hammer Set - AST5520
103.79
103.79
Set includes 1 lb., 2 lbs., and 2.5 lbs. dead blow ball peen hammersPolished steel peen provides a smooth striking surfaceComposite shank extending from head through handle delivers a more powerful blow and decreases vibrationThe internal steel canister with free flowing shot design maximizes dead blow action and minimizes rebound effectGritted wide flare handle end prevents hands from slipping These hammers are made of materials that resist most shop chemicals and are non-sparking. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Piece Go-Through Screwdriver Set - AST9503
25.39
25.39
"Go-Through" construction provides greater striking force than traditional cap endMagnetic tipsHexagon shaftMade of chrome vanadiumComes with a one year warranty This 3 piece set includes #2 x 18" Philips screwdriver with green handle; T15 x 15" with orange handle; and 5/16" x 18" slotted screwdriver with blue handle. Most Screwdrivers & Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Piece Impact Flip Socket Set - AST7843
18.49
18.49
1 - 19mm and 21mm flip impact socket1 - 3/4" and 13/16" flip impact socket1 - 3" extension barIncluded in a blow-molded case This 3 piece impact flip socket set fits most applications requiring SAE or Metric fittings for lug nuts. Most Socket Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Piece Offset Handle Long Reach Pliers Set - AST9416
31.39
31.39
Comfortable double padded cushion gripConstructed of drop-forged, heat treated, fully polished chrome vanadium steelOffset handle provides more leverage and pulling powerEasier to reach difficult and tight placesSpring loaded3 piece set includes: 11" needle nose pliers, 11" cutting pliers and 11" needle nose hose cable pliers. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Piece Quick Release Pipe Wrench Set - AST7160
48.97
48.97
Designed with fewer moving partsSelf adjusting quick release works well in confine areasMaximum effective gripping range for each wrench: 10" is 1-5/8" (40mm), 14" is 2" (50mm), 18" is 2-3/8" (60mm)Excellent tool for adjusting tie rods and suspension rods This Quick Release pipe wrench set is ideal for use in the automotive, plumbing, and farming industries. Its designed with the strength and durability to last! This 3 piece set includes the following sizes: 10", 14" and 18". Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Piece Seal and O-Ring Puller Set - AST9519
19.59
19.59
Quickly and easily removes O-rings, grease and oil sealsSpecial angle on the tool head provides better access than the traditional seal pullers3 different lengths and tips fit nearly all seal applicationsSimply insert the tips, press and pullIncludes 4.6", 6", and 6.5" pullers. Most Other Specialty Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Ton Jack Stands - Pair - ASTJT03
42.89
42.89
Extra-heavy dutyDuctile steel center post and pawl for added strengthSaddle column provides ratchet action height adjustmentPositive lock handle cannot be disengaged until load is off the saddle columnLock handle can be used as a carrying handle Four legged steel base for added strength. Sold in pairs. MEETS ANSI STANDARD FOR PERFORMANCE AND SAFETY. Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3 Way Swivel Air Coupler - AST3SB10
6.29
6.29
Capacity: 160 PSI Net Weight: 1/3 lb. Provides 3 way swivel action for tangle-free operations of air hose with all air tools. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3.5inch Digital Tire Inflator with Hose - AST3018
91.99
91.99
MPN #AST3018. Astro Pnuematics 3.5" Digital Tire Inflator with Hose. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/4 Ton Dual Wheel Dolly - ASTWD1500EX
744.69
744.69
? 3 Ton Hydraulic bottle jackHeavy duty safety chain for securing the wheelsTubular lifting arm 3" Rear swivel casters and rigid 3 1/2" front wheelsLift arms with ball bearing rollers Remove, transport and replace dual wheels and tire assemblies effortlessly. This 3/4 Ton Dual Wheel Dolly has a 3 ton bottle jack that provides over 6-1/2" of lift and tilts wheel assembly 7 degrees to prevent damage to wheel seal. The heavy duty safety chain is to secure the wheels. The tubular lifting arms with ball bearing rollers make it easier to rotate vehicle rim for the bolt pattern alignment. Also has 3" rear swivel casters and rigid 3-1/2" front wheels provide easy maneuverability. Also has an adjustable height push bar that provides unobstructed access to the hub area. Meets ANSI standard for performance and safely. Most Creepers, Dollys & Ramps products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/4 Ton Under Hoist Stand - AST1175N
117.49
117.49
Rugged constructionQuick adjust spin handle with thrust bearingLightweight, slender design12" Diameter base provides maximum stabilityDiamond Plate saddle grips the load This 3/4 Ton Under Hoist Stand is made strong for support when transferring load. It's lightweight, slender design makes handling easy, even in close quarters. Also it has a quick adjust spin handle with thrust bearing, which eliminates wear and provides ease of turning under load. This meets ANSI standard for performance and safety. Most Hoists, Stands & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Arbor for AST400E Smart Eraser Pad - AST400E-AR
2.29
2.29
Capacity air drill with a 4000 RPM Free SpeedUse with the pin-stripe removal pad Recommended to be used with the 400E and 3/8". Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Drive 72 Teeth Quick Release Ratchet - AST9331
41.99
41.99
Quick socket release buttonMid ratchet thumb wheel drive for fast turning of loose nutsWorks well in confined areas where standard ratcheting action is difficult or limitedHeavy Duty 72 Teeth ratchet mechanismEliminates hand-ratcheting to accomplish run-down Made of CR-V Steel with satin and black finish. Ratchet is 7-3/4" long. Most Ratchets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Drive Mini Wobble Air Ratchet - AST1119
73.19
73.19
? ? Wobble drive provides added flexibility to reach additional hard to reach areas? Compact and lightweight? Ideal tool for confined working areas such as under dashboard work? Ergonomically designed black composite body? Overall length 5-1/2" (140mm)? ?. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Drive Ratchet with One-Hand Reverse Function - AST9728
22.97
22.97
One-Handed easy to use forward and reverse control function built into handle60 Tooth gear system minimized arc swing for accessibility to hard to reach fastenersErgonomically designed 2-Tone soft rubber handles for greater control and gripChrome vanadium alloy steel for maximum strengthQuick release button for easy changing of sockets. Most Ratchets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Drive Slim Head Ratchet Wrench - AST1238
61.99
61.99
Slim Head design allows for access to hard to reach areasIdeal for body shops and repair shops to work in areas such as under-dashboard and confined space engine repairsWorking torque range from 5 ft. to 20 ft./lbs"Precision Forged" ratchet yoke made of Cr-Mo alloy steel with optimized heat treatment to maintain peak performance and prevent "Spreading" which makes other air ratchets lose powerPrecision machined anvil ensures that ratchet pawl and yoke can properly engage with each other at any position. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Filter, Regulator and Lubricator with Gauge - AST2616
85.49
85.49
Prevents costly damage to air tools caused by rust, scale and moistureConvenient minimum installation time into your compressed air systemProvides clean, dry, regulated compressed air over a wide range of airflows with accurate control and fast responseEfficiently traps moisture while passing through clean, dry compressed airGauge has rugged polycarbonate case with 2" face 1/4" or 3/8" NPT with Max. 135 PSI. 9-2/5" x 2-2/5"; 3 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch Flexible Extension Bar 230mm - AST9321
18.19
18.19
3/8" Square drive9" LengthManufactured from high quality chrome vanadium steelProvides access to hard to reach areas and awkward socket placements Suitable for all hand ratchet applications. Most Socket Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch NPT Filter With Regulator And Gauge - AST2615
63.19
63.19
Prevents costly damage to air tools caused by rust, scale and moistureConvenient minimum installation time into your compressed air systemGauge has rugged polycarbonate case with 2" face3/8" NPT with 0-160PSI gauge Provides clean, dry, regulated compressed air over a wide range of air flows with accurate control and fast response. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch x 100' Air Hose Reel - AST3602
30.49
30.49
Air Inlet: 1/4" Hose Outlet: 1/4" (3/8" Option)Diameter: 17-1/2"Width: 13" (handle included)Height: 18-1/4"Comes with 1/4" swivel adapter. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch x 50' Auto Rewind Non-Conductive Hose Reel - AST3688
180.99
180.99
300 PSI Air hose reelNon-conductive hose eliminates the possibility of combustion during useAutomatic rewindSolid rubber stopper4 way directional rollers Multi position mounting arm allows for floor, wall, or ceiling mounting. Specs: Capacity: 3/8" x 50' hose diameterAir Inlet: 1/4"Hose Outlet: 1/4"Shipping weight: 55 lbs. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 3/8inch x 50' Automatic Rewind Hose Reel with Hose - AST3682
134.29
134.29
Spring located in the middle drum to ensure the stability of the whole unitL-shaped base with groove reinforcement ensures stable support300 psi air hose reel with automatic rewindUnit has a solid rubber stopper, 4-way directional rollers, 2 position roller bracket assembly and a non-conductive hoseMulti-position mounting arm which allows for floor, wall or ceiling mounting Specifications: Capacity: 3/8" x 50'; Hose Diameter: 15" (380mm); Width: 5.5" (140mm); Height: 16.70" (424mm); Air Inlet: 3/8"; Air Outlet: 3/8"; Hose Outlet: 1/4". Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 30 LED 25' Corded LED Light - AST6315
37.43
37.43
LED lifetime rated up to 100,000 hours25' SJTW 18AWG/2C cordUnit is shatterproofPVC handle and tip increases grip and absorbs shock to extend the life of the lightUses standard 120V AC input, transforms to 12V DC outputETL approved This LED light has 30 leds that provide bright, non-glare light which equals the same brightness as 550 lumens. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 30 LED Corded Light with Cigarette Lighter Adapter - AST6316
9.19
9.19
Shatterproof plexi-glass bulb coverLED lifetime rated up to 100,000 hours12V DC power6' cord with cigarette lighter adapter and alligator clips. spt-2 cordETL approved Alligator clips and cigarette lighter adapter allows for powering light via terminal style automotive. PVC handle and tip increases grip and absorbs shock to extend the life of the light. This LED corded light has 30 leds that provide bright, non-glare light which equals the same brightness as 550 lumens. Most Gauge Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 30 Ton Bottle Jack - ASTAME30
284.00
284.00
Ribbed Steel lifting saddle prevents slippageInternally machined oil passagesDrop forged steel baseEasy to use release valveNo leak "Uni-weld construction" Widely used in various fields such as machinery, construction, and automotive industries. This 30 Ton Bottle Jack is made with the safety oil by-pass system which prevents over extension and causing damage to the cylinder. Also provides for longer wear life with the internally machined oil passages, smooth bearing surfaces and close tolerance. Its easy to use release valve prevents over traveling ram. This bottle jack meets ANSI standard for performance and safety. Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Page (4 of 12)
1 2 3 4 5 6 7 8 |
