Buy "astro pnuematics" online - search for the best price - compare prices
Page (2 of 12)
1 2 3 4 5 6 |
Astro Pnuematics 11 Piece Brake Pad and Caliper Service Tool Kit - AST7860
54.19
54.19
Magnetic socket adapterIncludes 8 adapters for brake assembliesFor rotating pistons back into the caliper to provide clearance for the new padsPrevents damage to the piston and bootKit complete in blow molded case This 11 piece brake pad and caliper service tool kit is designed for use with Mercedes, BMW, Volkswagen, GM, Audi, Ford, Honda, Subaru, Mazda, Nissan, Mitsubishi, Toyota, Land Rover and 4-Wheel drive vehicles. Set includes: 1- #0 Adaptor 1- Separating Disk 1- #2 Adaptor 1- #3 Adaptor 1- #4 Adaptor 1- #5 Adaptor 1- #6 Adaptor 1- #7 Adaptor 1- #8 Adaptor 1- #9 Adaptor 1- Main Body. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12 Piece 3/8inch Drive 6 Point and 12 Point Metric Offset Flexible Crowfoot Wrench
60.39
60.39
One 3/8" square drive extension can be used for all flex crowfoot socketsFlexible endsBottom flare designFolds up to 190 degreesFeatures mirror finish These replace the traditional flare nut wrench! They allow you to work in hard-to-reach areas at up to 110 degrees. This set includes 6 point 3/8" Drive Offset Flexible Crowfoot Socket Wrench in sizes 8, 9, 10, 11, 12 and 13mm and 12 point 3/8" Drive Offset Flexible Crowfoot Socket Wrench sizes 14, 15, 16, 17, 18 and 19mm. Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12 Piece 3/8inch Drive 6 Point and 12 Point SAE Offset Flexible Crowfoot Wrench Set
45.99
45.99
One 3/8" square drive extension can be used for all flex crowfoot socketsFlexible endsBottom flare designFolds up to 190 degreesFeatures mirror finish These replace the traditional flare nut wrench! They allow you to work in hard-to-reach areas at up to 110 degrees. This set includes 6 point wrenches include sizes 1/4", 5/16", 3/8", 7/16, 1/2" and 9/16", and 12 point wrenches include sizes 5/8", 11/16, 3/4", 13/16", 7/8" and 15/16". Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12 Piece 3/8inch Drive SAE Crowfoot Wrench Set - AST7112
61.69
61.69
Flare nutBlow molded case for easy storage and transport Sizes: 5/16", 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", 15/16" and 1". Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12 Piece Pliers Set - AST9467
45.24
45.24
Double Dipped HandleFine Polished FinishCarded Double Blister PackagingComfort GripMade of chrome vanadium Set includes: 6" long nose pliers, 6" diagonal pliers, 6" linesman pliers, 6" slip joint pliers, 6" groove joint pliers, 8" long nose pliers, 8" diagonal pliers, 8" linesman pliers, 8" slip joint pliers, 8" groove joint pliers, 10" groove joint pliers and 12" groove joint pliers. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12 Ton Air Bottle Jack - AST5300
139.99
139.99
Designed for operating either manually or pneumaticallyAir hose can swivel in any direction of connection from air source Fitted with a safety valve against overloading2 piece long handle allows ease of pumpingExtension screw gives added height when necessary Minimum air pressure required is 125 psi. Speedy and versatile, air/hydraulic bottle jack is far quicker than using conventional hand operated hydraulic equipment and much safer since air power permits one-handed operation and enable use to watch load more closely. Heavy duty design makes them ideal for a wide variety of automotive, truck, industrial and construction work. Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12 Ton Jack Stands - Pair - ASTJT12
169.99
169.99
Extra-heavy dutyDuctile steel center post and pawl for added strengthSaddle column provides ratchet action height adjustmentPositive lock handle cannot be disengaged until load is off the saddle columnLock handle can be used as a carrying handle Four legged steel base for added strength. Sold in pairs. MEETS ANSI STANDARD FOR PERFORMANCE AND SAFETY. Most Jacks & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 120 AMP Combination Gas / No Gas Welder and Cart - ASTCOMBI120KT
569.99
569.99
Ideal for light industrial applications, auto body, light fabrication, maintenance, repair and farm or ranchLightweight portable unitCombination indoor (gas) and outdoor (no gas) weldingFan cooled for increased duty cycleWelder cart - heavy duty steel construction, two 7.5" fixed wheels and two 3" swivel casters Welder Cart features: heavy duty steel construction, heavy duty wheels - two 7.5" fixed wheels and two 3" swivel casters, 3 shelves for easy access to supplies, cart size: 27-1/2"(L) x 16-1/3"(W) x 28"(H), top shelf size: 17-3/4"(L) x 11-1/2"(W), bottom shelf size: 27-1/2"(L) x 11-1/2" (W), weight capacity: 176lbs. approximately. Most Welding Tools & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 120 LED Underhood Light - AST6310
181.79
181.79
Special design extra thin wall, deep length impact sockets allows for removal and installation of transmission and differential end yoke locknuts on a large range of trucksSet Includes 2", 2-1/8", 2-1/4", 2-3/8", 2-1/2", 2-5/8" and 2-3/4" Sockets This kit eliminates the need to modify impact sockets or to purchase expensive tools specially designed to perform this type of removal and installation. Most Spot & Trouble Lights products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 1250 Lb. Capacity Engine Stand - ASTES1250
150.99
150.99
Fully adjustable engine mounting head that rotates 360 degrees and enables engine to be placed in desired work positionHeavy gauge steel mechanical tubing prevents excessive frame flexFour wheel design provides maximum stability and supportHas two 3" diameter rigid wheels in back and two 3" swivel casterSafety lock pin This engine stand has extra support bars for V8 engines. Also has a storage bin for parts and a tools. Most Hoists, Stands & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 12inch Bamboo Paint Paddle - AST4586
46.69
46.69
1,000 per case. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 13inch Heavy Duty Hand Riveter - AST1423
35.29
35.29
Patented structure increases power and reduces shakeShortest long arm riveter which can operate up to 1/4" stainless steel rivetsShorter handle with double compound hinges that maximize leverageErgonomic grip for easy operation3 piece jaws are made of Cr-Mo steel This 13" Heavy Duty Hand Riveter is ideal for working in hard-to-reach areas. Also one of our most versatile and powerful hand riveters, taking the hard work out of setting large diameter blind rivets. A one-piece collet case eliminates the need to adjust the tool when changing rivet diameters. Includes 5 nose-pieces: 1/8", 5/32", 3/16", 1/5", and 1/4". Most AC Valves & Tubing products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 15 Piece Master Disconnect Kit - AST78930
40.99
40.99
Includes Fuel and Transmission Line Disconnect SetIncludes Oil Cooler Line RemoverIncludes Air Conditioning and Fuel Line Disconnect Tool SetMade of Anodized aluminumPackaged in a blow molded case A complete set of disconnect tools stored in a handy blow-molded case. Fuel & Transmission Line Disconnect Set Anodized aluminum Separate fittings on fuel lines, fuel filters & fuel tank return lines Sizes: 1/4", 5/16", 3/8" & 1/2" Oil Cooler Line Disconnect ToolSeparates automatic transmission oil cooler lines on Ford Taurus and Escort with AXOD and ATX transmissions Fuel line disconnect tool allows damage free fuel line quick connect coupler release Fits any 5/16" or 3/8" fuel line found on GM, Ford or Chrysler cars Ford fuel line coupling tool provides easy, damage-free fuel line separation Works on 1990 and newer Ford Ranger and Explorers with 4.0L, 6 cylinder engines Disconnect tool allows quick separation of quick connectors found on radiators, transmissions and power steering lines Releases the fingers on transmission-to-radiator oil cooler line easily without damage to the hose or connector Works on 1986 and newer Ford Taurus and Mercury Sable with an AXOD, AOD or ATX transmission Quick disconnect coupler tool slides down the line and into the connector; separating the clip apart without damaging the quick connect seals allowing removal of clip Works on late model Ford and GM vehicles Oil Cooler Line Remover Anodized aluminum This unit is used to disconnect transmission oil cooler lines Works on 2003 and 2004 Ford Explorer (V8), 2004 Ford F150, and 2004 Cadillac CS Unique design to clear the flare and disconnect the new style clips Air Conditioning & Fuel Line Disconnect Tool Set Sizes 5/16", 3/8", 1/2", 5/8", 3/4" and 7/8" Air Conditioning & Fuel Line Disconnect Tool Allows easy disconnection of air conditioning lines & quick connect fuel lines Six distinctive tools allow the disconnecting of spring lock couplings air conditioning lines found on Ford and Chrysler Allows usage on fuel line quick connect couplings found on GM, Ford, and Chrysler 5/16" Disconnect Tool allows usage on push lock connectors found on Ford radiators and transmission lines. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 15 Piece Professional Metric Crowfoot Wrench Set - AST7115
70.29
70.29
Flare nutBlow molded case for easy storage and transport Set includes: 3/8" Drive sizes: 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 15mm, 16mm, 17mm, 18mm, and 19mm; 1/2" Drive sizes: 21mm, 22mm and 24mm. Most Wrenches & Wrench Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 16 Piece Punch and Chisel Set - AST1600
23.99
23.99
Chrome vanadium steelHeat treatedPunches: (5) Taper punches, (5) Pin punches, (2) Center punchesChisels: (3) Clod chisels, (1) Chisel gauge and (1) Plastic storage trayThis 16 piece punch and chisel set includes the following sizes: Taper Punch: 3/32" x 5-1/4", 1/8" x 5-3/4", 5/32" x 6", 3/16" x 6-1/4", 1/4" x 6-3/4"; Cold Chisels: 3/8" x 5-1/2", 1/2" x 6", 5/8" x 6-1/2"; Pin Punch: 3/32" x 4-1/4", 1/8" x 4-3/4", 5/32" x 5", 3/16" x 5-1/4", 1/4" x 5-3/4"; Center Punch: 1/8" x 5", 3/16" x 6" . Most Cutting & Drilling Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 17 Piece 1/2inch Drive Impact External and Internal Torx Socket Set - AST7806
73.99
73.99
Smaller drive size allows use in tighter areasBlow molded case for easy storage Internal and External Thin Wall Sockets includes 3 piece 1/4" Drive External Torx: E4, E5, E8; ? 3 piece 3/8" Drive External Torx: E10, E12, E14; 4 piece? 1/2" Drive External Torx: E18, E20, E22, E24; 3 piece? 3/8" Drive Internal Torx: T40, T45, T47; 4 piece? 1/2" Drive Internal Torx: T50, T55, T60 T70. Most Socket Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 18 Piece Brake Caliper Wind Back Tool Set - AST78618
64.99
64.99
Adaptor plates with thrust bolt assembly and reaction plate are precisely madePrevents damaging pistons and sealsUpdated adaptor set applicable for side variety of vehiclesDurable and save time Kit includes: holder, right main body, left main body and 15 adapters. Most Brake Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 18inch Masking Machine - ASTMM18
107.99
107.99
Includes bars for two (2) paper rolls and four (4) tape rollsLarge adjustable washers maintain paper alignmentWing nuts for easier paper loadingSharp, anodized blade for smooth cuttingLarge storage tray on bottom for tools Sandpaper tray on side and bar for holding spray gun. Weight: 33 lbs. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 1inch Heavy Duty Impact Wrench with 6inch Anvil - Double Hammer - AST1869
749.99
749.99
Maximum torque is 1800 ft./lbs.Includes a high efficiency 6 vane air motor6" anvil makes tool perfect for the demanding world of truck tire serviceFree speed: 5000 RPMSwept-back side handle and protective rubber boot This unit is ideal for tire work on trucks, buses and off-road, farm equipment. "Pin-less" impact mechanism submits brute force strike with low vibration. A six-position power management/regulator (3 forward and 3 reverse) with air inlet: 45 degree angle. Air Exhaust - Upward away from work piece.? Working Torque Range: 300-1400 ft/lbs, (408-1904) NM, Maximum Torque: 1800ft/lbs (2448NM); blows per minute: 750; free speed: 5000rpm.; Weight: 27lbs (12.25kg). Most Torque & Impact Wrenches products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 2 Piece 16inch Snap Ring Plier Set - AST9402
48.99
48.99
Internal/External heavy duty circlip pliers setFeatures replaceable points and spring ratchet locking mechanism to securely hold against circlip tensionComes in a blow molded case Specs: Tip diameter: 0.12" (3mm)Internal: 3-1/16" - 6-1/4" (78mm-159mm)External: 3-1/2" - 6-1/2" (89mm-159mm)Spread: 3-1/4" (85mm)Length: 16"Tip size: 0.12" (3.0mm) -0? , 45? , 90? set. Most Pliers & Pliers Sets products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 2 Piece Construction Gravity Feed Paint Gun Holder - ASTGFH1000
10.39
10.39
2 piece gravity feed gun holder works great with all gravity feed gunsTop strainer holder may be removed for additional clearanceStrainer holder swivels away from cup. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 2 Quart Pressure Pot - Wide Mouth - AST4010S
117.89
117.89
Stainless steel constructedAllows steady, constant material flowMouth diameter: 4.5"Allows use of any conventional spray coating? This is a great complimentary item for any HVLP spray system. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 2 Quart Pressure Pot with Silver Gun and Hose - AST2PG8S
168.99
168.99
1.7mm nozzleAllows operator to mix and paint 2 quarts (1893cc) at a timeSpray gun6 ft. length fluid hose6 ft. length air hose Excellent for spraying large areas such as busses, trucks and vans. It comes equipped with pressure gauge and fluid pressure regulator for accurate settings. Most Air Tools products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 2 Shelf 30inch Plastic Service Cart - AST8334
172.89
172.89
Hinged lid closes and locks with a standard pad lock (lock not included)For shop, office, warehouse or medical facility useSize: 16" (W) x 30" (L) x 31 "(H)Has two handles on each sideCart can be pushed or pulled from either side Trays are 4" deep and can hold up to 300 lbs. Cart has 4" swivel heavy duty casters. Tread will not mark floors. Weight: 26 lbs. Most Tool Boxes & Accessories products are available for in-store pickup from Advance Auto Parts.
Astro Pnuematics 2 Ton Double Plunger Low Profile Service Jack - AST200LP
270.69
270.69
Very low pick up point of 2-3/4"Double plunger8 pumps to full heightQuick pumpLifting arm reinforced with internal steel beam Other features include: By-pass system; Overload protection; 1.9 ton on single stroke under normal load; Extra long 2 piece handle for easier pumping and reach under vehicles; Universal 45 degree guarantees pumping at any position under load; Steel casters; Reinforced side frames; Foam covered handle. Meets ANSI standard for performance and safety specifications. Specifications: ? Min. saddle height: 2-3/4" (70mm)Max. saddle height: 19-5/8" (495mm)Chassis length: 26-3/4" (680mm)Height with handle: 56" (1420mm)Frame height: 5-1/2" (142mm)Saddle diameter: 4-3/4" (120mm)Net weight: 91 lbs. (41kg). Most Tire Repair products are available for in-store pickup from Advance Auto Parts.
Page (2 of 12)
1 2 3 4 5 6 |
