Buy "alc keysco" online - search for the best price - compare prices
Page (2 of 2)
1 2 |
ALC Keysco Keysco Van Stand - ALC77781
247.99
247.99
48"L x 16"W x 18"HSturdy work stand to reach tops of vans and trucksUse to reach and service engines on large trucksSafety yellow with non-skid surfacesMade in the USA When a ladder is just to much or not enough stepping room, be sure to have this van stand handy.? It's built with the safety and the room needed.? Also it's easy to store with the folding legs. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Masker Prep Station - ALC78015
614.99
614.99
Holds the most popular sizes of masking paperFeatures a separate bar for plastic rollsPaint gun holder and convenient upper tray for miscellaneous tools and suppliesFour swivel casters with two locking to prevent rollMade in the U.S.A. Large top tray 22" x 46", holds tools and tape; holds 36" plastic on top bar; holds up to 2 rolls of 18" paper - bar #2; holds up to 2 rolls of 18" paper - bar #3; holds up to 1 roll of 36" paper - bottom paint gun holder. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Medium Duty Hood - ALC40024
48.19
48.19
Complete fabric hoodComplete head coverageIncludes internal bump capHas rear breather ventsLens 5" x 6" When sandblasting, be sure to have the right protections.? With this medium duty hood you can.? It provides complete head coverage.? Made strong and durable to last. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Medium Second Cut Slapping File - ALC77505
35.69
35.69
Ideal for panel shrinking and metal removalShaped for easy hand useFully heat treatedMade in the US This formed file is a medium second cut slapping file. It's designed for easy hand use.? Made strong and durable to last!. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Monkey-On-A-Stick Jack Set - ALC77043
147.09
147.09
55" long solid alloy 3/4" rod eliminates need for extension tubes Up to 3,000 lbs. push/pull power Multiple position handle for hard to reach areasFriction jack features 5 hardened friction plates for minute adjustmentsMade in the U.S.A. This tool is a must have for every body shop since 1929.? It's the most versatile tool available; it pushes, pulls, aligns, spreads and straightens.? Also this 4 piece jack set is ready to use, no set up is required.? It works great for the long reaches, no extension tubes needed. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Siphon Feed Sand Blaster Kit with 50lb Capacity - ALCF50
148.99
148.99
80-125 PSIHose Size: 3/8" Inside Diameter x 7 ft.Includes three steel nozzles; sizes-13/64", 1/4", and 5/16" and three air jets; sizes-5/64", 1/8" and 5/32"Includes a two year warranty Made in the USA This F50 model siphon feed sand blaster is a free standing open top tank, which has a 50lb. capacity.? It's portable, simple to use with professional results.? Use with abrasives or liquids on metal, wood, cement, plastic or other surfaces. Easy to set up and operate. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Soda Blast 1/2inch Conversion Kit - ALC40415
186.00
186.00
Environmentally friendly? Cleans engine compartments and other areas without harming the surface? Will not cause pitting or warping like other abrasives? Safe to use on aluminum and fiberglass? Will not harm rubber, plastic or glass The? Soda Blast is a revolutionary new concept.? This accessory kit will turn almost any pressure blaster into a soda blaster.? Available in 3/8" plumbing models (typical import blasters) and 1/2" for most U.S. made blasters.? Change over takes 10-15 minutes.? ? Made in the USA, 2 year warranty. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Soda Blast 3/8inch Conversion Kit - ALC40438
186.00
186.00
Environmentally friendly? Cleans engine compartments and other areas without harming surface? Will not cause pitting or warping like other abrasives? Safe to use on aluminum and fiberglass? Will not harm rubber, plastic or glass The Soda Blast is a revolutionary new concept. This accessory kit will turn almost any pressure blaster into a soda blaster. Available in 3/8" plumbing models (typical import blasters) and 1/2" for most U.S. made blasters. Change over takes 10-15 minutes. Made in the USA, 2 year warranty. Most Commercial Tools & Equipment products are available for in-store pickup from Advance Auto Parts.
ALC Keysco The Hustler Stick Alignment Bar - ALC77175
156.39
156.39
Heavy duty 1-1/4" diameter tubing with two welded hooks for strength and versatility. 1/4" chain, 6' long, hooks on both ends. Made in U.S.A. Hustler stick alignment bar for bumpers, panels, hoods, decks and brackets. Indispensable when versatility of a chain hookup is needed. Made with the strength and durability to last!?. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Vantage Paper Tree Masker - ALC33004
353.99
353.99
Bar 1; 3" rollBar 2; 3" to 6" rollBar 3; 3" to 12"Bar 4; 3" to 18"Made in the USA This is the most popular of the Vantage Tool masker.? It's made to hold 4 bars of paper ranging from 3" to 18". Also it's made with the stability and maneuverability needed in any paint shop. Most Masking Film, Tape & Supplies products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Viking Dual Piston Straight Line Sander - ALCV100
260.99
260.99
Made in the U.S.A. by VikingOriginal straight line sander from VikingStrength of dual action pistonRemoves material from large areas quicklyTwo year warranty Removes material from large areas quickly. Provides smooth operation on all surfaces - metal, putty, and fiberglass. Dual piston makes this a powerful tool. Specifications include: 2400 SPM, 4 cfm, required pressure: 90-100 PSI, supplied pad size: 2-3/4" x 17" Klip-on. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Viking Single Piston Straight Line Sander - ALCV101
260.99
260.99
Made in the U.S.A. by VikingViking reputation of quality for over 40 yearsWorks well on all surfaces, metal, putty and fiberglassSmaller size for hard to reach areasTwo year warranty The "Mini Vike" is smaller for hard to reach and smaller areas.? It is lightweight to reduce operator fatigue. Specifications include: 2400 SPM, 4 cfm, 90-100 required PSI, supplied pad size: 2-3/4" x 11" P.S.A. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
ALC Keysco Wheel Dollys (Pair) - ALC77788
294.99
294.99
Each wheel dolly have 4" heavy duty swivel wheels and two are locking Fully welded all steel frameSold by the set of 2 eachDolly holds 1200 lbs.Made in the USA This pair of wheel dolly's make it easier to maneuver wheels.? Saves time and energy! Made with the quality and durability to last!. Most Polishers, Buffers & Pads products are available for in-store pickup from Advance Auto Parts.
Page (2 of 2)
1 2 |
