Buy "wheels" online - search for the best price - compare prices
Recent searches:
air dam wheels full exhaust 1988 conquest air bo head light switch 145 inch ssbc rotors brake pads dana 30 ring and pin engine block conquest intake pipe fuel injectors f1987 conquest engin fuel level unit full exhaust conque fuel injectors mitsu
Page (2191 of 2194) | | 2187 2188 2189 2190 2191 2192 2193 2194 | |
StopTech Front 13 Inch 4 Piston Big Brake Kit Infiniti G37x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 6 Piston Big Brake Kit Infiniti G35x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Infiniti G37x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 6 Piston Big Brake Kit Infiniti G37x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 13 Inch 4 Piston Big Brake Kit Honda Civic EX Sedan 9395 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 13 Inch 4 Piston Big Brake Kit Honda Civic GX Sedan 0105 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit Chevrolet Suburban 1500 0005 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit GMC Sierra 1500 9903 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
TeraFlex 4" ENDURO LCG Suspension Lift Kit without Shocks
TeraFlex 4" ENDURO LCG Suspension Lift Kit without Shocks Fits: 2004-2006 Jeep Wrangler Unlimited TJL & Rubicon Model Special Note: Maximum Tire Size: 32" Product Overview: The TeraFlex 4" ENDURO LCG Suspension Lift Kit without Shocks is designed for the entry-level off road enthusiast that wants suspension performance with very little modification to the vehicle frame. The ENDURO Long Arm System will transform your current Wrangler's handling capabilities both on and off road. The re-designed long arm bracketry allows for easy installation and access to the transfer case without disassembly of suspension components. Kit Includes: 2 Front Coil Springs 2 Rear Coil Springs 2 Front Bump Stops 2 Rear Bump Stops 2 Front Sway Bar Disconnects 2 Front Brake Line Relocation Brackets 2 Rear Sway Bar Links 2 Rear Upper Adjustable Monster Control Arms 2 Rear Lower Shock Relocation Brackets 2 Lower Long Arms 2 Long Arm Subframe Brackets 1 Front Adjustable Track Bar 1 Steering Box Skid Plate 1 Pitman Arm Kit Specifications: Installation Difficulty: Difficult Installation Time: 14-18 hours on average Weight: 300 lbs. Features: Low center of gravity with maximum ground clearance Increased highway handling and maneuverability Allows suspension travel for off-road articulation HD 1.75" DOM FlexArm Tubing for superior strength HD Monster Rod Ends for strength, adjustability and customization Special Note:Oversized Package: MUST BE SHIPPED USING FREIGHT TRUCK ONLY! Special Notes: 1- Full wheel alignment needed 2- CV Style Driveshaft and HD or Extreme Short Shaft SYE Kit recommended 3- CV Style Drive Shaft and Extreme Short Shaft SYE Kit Recommended 4- Rubicon Models add Compressor Mount Plate, TF-4847400 5- Some welding required 6- If using stock wheels and tires over 32" in diameter, wheel spacers are required to allow unobstructed turning 7- Rubicon Models add 1" Body Lift, TF-1942100 or TF-1900100, to lower the bellyup plate to allow room for the transfer case 8-Transfer Case Lowering Kit recommended for short wheelbase Rubicons Years Covered: 2004, 2005 and 2006
TeraFlex 3" ENDURO LCG Suspension Lift Kit without Shocks
TeraFlex 3" ENDURO LCG Suspension Lift Kit without Shocks Fits: 2004-2006 Jeep Wrangler Unlimited TJL & Rubicon Model Special Note: Maximum Tire Size: 32" Product Overview: The TeraFlex 3" ENDURO LCG Suspension Lift Kit without Shocks is designed for the entry-level off-road enthusiast that wants suspension performance with very little modification to the vehicle frame. The ENDURO Long Arm System will transform your current Wrangler's handling capabilities both on and off road. The re-designed long arm bracketry allows for easy installation and access to the transfer case without disassembly of suspension components. Kit Includes: 2 Front Coil Springs 2 Rear Coil Springs 2 Front Bump Stops 2 Rear Bump Stops 2 Front Sway Bar Disconnects 2 Front Brake Line Relocation Brackets 2 Rear Sway Bar Links 2 Rear Upper Adjustable Monster Control Arms 2 Rear Lower Shock Relocation Brackets 2 Lower Long Arms 2 Long Arm Subframe Brackets 1 Front Adjustable Track Bar 1 Steering Box Skid Plate 1 Pitman Arm Kit Specification: Installation Difficulty: Difficult Installation Time: 14-18 hours on average Weight: 285 lbs. Features: Low center of gravity with maximum ground clearance Increased highway handling and maneuverability Allows suspension travel for off-road articulation HD 1.75" DOM FlexArm Tubing for superior strength HD Monster Rod Ends for strength, adjustability and customization Special Note:Oversized Package: MUST BE SHIPPED USING FREIGHT TRUCK ONLY! Special Notes: 1- Full wheel alignment needed 2- CV Style Driveshaft and HD or Extreme Short Shaft SYE Kit recommended 3- CV Style Drive Shaft and Extreme Short Shaft SYE Kit Recommended 4- Rubicon Models add Compressor Mount Plate, TF-4847400 5- Some welding required. 6- If using stock wheels and tires over 32" in diameter, wheel spacers are required to allow unobstructed turning 7- Rubicon Models add 1" Body Lift, TF-1942100 or TF-1900100, to lower the bellyup plate to allow room for the transfer case 8- Transfer Case Lowering Kit recommended for short wheelbase Rubicons Years Covered: 2004, 2005 and 2006
Poison Spyder Rear Brawler Tire Swing Bare Steel with CB Mount
**TRUCK FREIGHT WILL APPLY** Poison Spyder Rear Brawler Tire Swing Bare Steel with CB Mount Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: The RockBrawler rear bumper for JK is designed to combine hard core off-road performance with full features. This bumper is fabricated from 3/16" plate steel, CNC laser-cut and precision brake-formed into a low profile, high clearance design. The RockBrawler rear bumper is compatible with the stock tow hitch. Unlike the Poison Spyder BFH rear bumpers for JK, the RockBrawler rear bumper can be mounted without cutting or altering the Jeep's frame rails. The faceted design of the RockBrawler rear bumper provides the best ground clearance and departure angle possible in a bumper that doesn't require frame modifications. The RockBrawler rear bumper has a built-in step/recess to provide access to the rear of the Jeep as well as clearance for the spare tire. The RockBrawler spare tire carrier is built from the highest quality components. The main structure of the tire carrier is fabricated from NC-bent DOM tubing and laser-cut, precision brake-formed plate steel. The extreme duty hinge assembly includes a CNC machined spindle and housing, with a pair of Timken tapered roller bearings for smooth operation under the heaviest loads. The latch is a high quality automotive grade mechanism, concealed in a fabricated housing. There is a spring-loaded pin-lock with stainless steel slider plate that locks the tire carrier into the open position to keep it from swinging around while accessing the Jeep's tailgate. The latch and pin lock are both easily disengaged with a simple pull of a knob. The tire mount is adjustable up and down, as well as in and out, to accomodate a wide variety of tire sizes up to 42". The adjustability allows the tire to be mounted as low as possible for any tire size, to keep a low center of gravity. The included license plate mount places the license plate at the center of the spare tire. IMPORTANT: The spare tire mount requires a wheel with at least a 3" center hole. This includes most aftermarket wheels. The stock Jeep JK wheel does not fit. Upon request, we can leave off the license plate holder, which will allow mounting of a stock Jeep wheel. However you will not be able to use the license plate mount to place the plate in the center of the spare tire. If you would like this to be done for yours, please note in the comments when ordering. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
The Pinnacle Kwazar Liquid Crystal Waterless Wash Combo combines a heavily concentrated version of Pinnacle Liquid Crystal Waterless Wash with the amazing dual-action spraying action of the Kwazar Mercury Pro Spray Bottle as well as six super soft Gold Plush Jr. Microfiber Towels. Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba cleans your automobile without the use of water while leaving your paint with Pinnacle's famous show car shine. Dilute 1 part concentrate with 32 parts of water to create over four gallons of ready-to-use solution. The Pinnacle Kwazar Liquid Crystal Waterless Wash Combo includes: Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba is a luxurious waterless auto wash that safely cleans the most precious paint without dulling the shine. This high lubricity formula encapsulates road pitch, dust, and other common soil, safely allowing it to glide off the paint. You can use Pinnacle Liquid Crystal Waterless Wash to clean most exterior surfaces: glass, trim, brightwork, wheels, and more! Kwazar Mercury Pro 1 +Liter Spray Bottle (33 oz.) Kwazar Mercury Pro + 1 Liter Spray Bottles might be the best sprayers you ever use! Each trigger sprayer delivers twice the output per pump, trimming time and effort off every detail you do. The Kwazar Mercury Pro + 1 Liter Spray Bottle is a professional grade, adjustable, double-action sprayer suitable for any detailing job. Kwazar Mercury Pro + 1 Liter Spray Bottles are made from durable materials with Viton seals that provide excellent resistance to aggressive chemicals. Each Kwazar sprayer includes an integrated fluid filter and a translucent bottle with embossed scale for easy measuring. 6 Gold Plush Jr. Microfiber Towels Gold Plush Jr. Microfiber Towels have a deep pile and soft blend of fiber making them ideal for use with waterless and rinseless wash systems. Wash a section of the car by spraying Pinnacle Liquid Crystal Waterless Wash on the surface and lightly wiping. Flip the towel over and buff dry. Switch to a clean microfiber towel when the current one has become soiled. The Pinnacle Kwazar Liquid Crystal Waterless Wash Combo contains everything needed to clean light-to-moderate road soil, dust, and smudges from the paint. Dilute according to the direction. Mist and wipe a panel at at time. For more soiled automobiles use Pinnacle Liquid Gloss Rinseless Wash or Pinnacle Body Work Shampoo. Contents: 16 oz. Pinnacle Liquid Gloss Waterless Wash Concentrate with Carnauba 1 x Kwazar Mercury Pro +1 Liter Spray Bottle (33 oz.) 6 x Gold Plush Jr. Microfiber Towels A total retail value of $70.92. You save $20.93!
StopTech Rear 13 Inch 2 Piston Big Brake Kit Infiniti G35x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Infiniti G35x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 13 Inch 2 Piston Big Brake Kit Infiniti G37x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Infiniti G37x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 15 Inch 6 Piston Big Brake Kit Chevrolet Suburban 1500 0709 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Chrysler 300C SRT8 0609 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Porsche 997 GT3 0709 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 13 Inch 4 Piston Big Brake Kit Porsche 997 Carrera 2S 05 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Fits Stock WheelsTrophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Audi A6 Quattro 27T C5 0001 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering For race use only pads not includedTrophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
Poison Spyder Rear Brawler Bumper with Tire Swing Bare Metal
**TRUCK FREIGHT WILL APPLY** Poison Spyder Rear Brawler Bumper with Tire Swing Bare Metal Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: The RockBrawler rear bumper for JK is designed to combine hard core off-road performance with full features. This bumper is fabricated from 3/16" plate steel, CNC laser-cut and precision brake-formed into a low profile, high clearance design. The RockBrawler rear bumper is compatible with the stock tow hitch. Unlike the Poison Spyder BFH rear bumpers for JK, the RockBrawler rear bumper can be mounted without cutting or altering the Jeep's frame rails. The faceted design of the RockBrawler rear bumper provides the best ground clearance and departure angle possible in a bumper that doesn't require frame modifications. The RockBrawler rear bumper has a built-in step/recess to provide access to the rear of the Jeep as well as clearance for the spare tire. The RockBrawler spare tire carrier is built from the highest quality components. The main structure of the tire carrier is fabricated from NC-bent DOM tubing and laser-cut, precision brake-formed plate steel. The extreme duty hinge assembly includes a CNC machined spindle and housing, with a pair of Timken tapered roller bearings for smooth operation under the heaviest loads. The latch is a high quality automotive grade mechanism, concealed in a fabricated housing. There is a spring-loaded pin-lock with stainless steel slider plate that locks the tire carrier into the open position to keep it from swinging around while accessing the Jeep's tailgate. The latch and pin lock are both easily disengaged with a simple pull of a knob. The tire mount is adjustable up and down, as well as in and out, to accomodate a wide variety of tire sizes up to 42". The adjustability allows the tire to be mounted as low as possible for any tire size, to keep a low center of gravity. The included license plate mount places the license plate at the center of the spare tire. IMPORTANT: The spare tire mount requires a wheel with at least a 3" center hole. This includes most aftermarket wheels. The stock Jeep JK wheel does not fit. Upon request, we can leave off the license plate holder, which will allow mounting of a stock Jeep wheel. However you will not be able to use the license plate mount to place the plate in the center of the spare tire. If you would like this to be done for yours, please note in the comments when ordering. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
StopTech Front 13 Inch 4 Piston Big Brake Kit Audi Allroad 2 Pad Front Caliper 0106 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Audi Allroad 2 Pad Front Caliper 0106 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
