Buy "wheels" online - search for the best price - compare prices
Recent searches:
dana 30 ring and pin conquest intake pipe fuel injectors mitsu brake pads head light switch 1988 conquest air bo fuel level unit fuel injectors engine block full exhaust air dam full exhaust conque wheels 145 inch ssbc rotors f1987 conquest engin
Page (2190 of 2194) | | 2186 2187 2188 2189 2190 2191 2192 2193 2194 | |
StopTech Front 15 Inch 6 Piston Big Brake Kit Cadillac Escalade 0709 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit Infiniti M45 0609 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit Chevrolet Silverado SS 0405 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit Chevrolet Silverado1500 9904 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Audi S4 B5 9902 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering For race use only pads not includedTrophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Nissan 350Z 0608 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Dodge Challenger RT 0809 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 14 Inch 4 Piston Big Brake Kit Infiniti G35 0204 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 13 Inch 4 Piston Big Brake Kit Audi A6 C5 Quattro 27T 0001 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Audi A6 C5 Quattro 27T 0001 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 6 Piston Big Brake Kit Audi A6 C5 Quattro 27T 0001 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 13 Inch 4 Piston Big Brake Kit Audi A6 C5 Quattro 30L 0204 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Audi A6 C5 Quattro 30L 0204 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
TUF SHINE Black Restore is a unique new product designed to restore faded and oxidized black exterior trim. It will permanently revitalize older, weathered looking surfaces. More and more cars, SUVs, and trucks are restoring to plastic and vinyl cladding that offers great impact resistance while keeping the weight of your vehicle down. Unfortunately, the air and sun quickly age these parts. Faded, dull, and oxidized trim and quickly make your vehicle look old beyond its years. Now you can permanently restore and protect these pieces with TUF Shine Black Restore. Unlike similar products, TUF SHINE Black Restore will not wash off, even when blasted with a pressure washer. It is a water-based product that dries quickly with no oily residue and makes clean up a breeze. TUF Shine Tire Restore works on most hard plastic and rubber surfaces; it can also be used on tires to give them a deep black look and added protection. TUF SHINE Black Restore is similar to TUF SHINE Tire Clear Coat, but tinted black to restore faded and chalky rubber, trim and tires. It works great on cars, trucks, boats, ATV's, and even golf carts. You can use TUF SHINE Black Restore on black, hard plastic and rubber surfaces. It will not adhere to some softer materials like polyethylene, polyurethane, or similar waxy appearing plastics. It is best to test it on questionable surfaces by applying to an inconspicous spot and lightly scratching several days later. If it does not scratch off with moderate pressure, it should perform properly. For best results, clean the surface with TUF SHINE Tire Cleaner before applying TUF SHINE Black Restore. Failure to properly clean the surface will result in adhesion failure. You only need to clean the surface once with TUF SHINE Tire Cleaner. Once you apply Black Restore your rubber will be sealed and will clean easily with regular soap and water or with a pressure washer. Bonus Tip: After restoring your trim, tires, and plastics with TUF SHINE Black Restore, you can top with TUF SHINE Tire Clearcoat for even more protection! Application Instructions: Shake contents. TUF SHINE Black Restore contains special colorants which are NOT in suspension. SHAKE the container well and often during use to prevent settling of colorant. Surface must be cool and dry. DO NOT APPLY IN DIRECT SUNLIGHT, OR IN COLD TEMPERATURES BELOW 5O DEGREES. Squirt a small amount onto the applicator sponge. Wear waterproof gloves to prevent staining. Apply a thin even coat to the surface. Slight milky buildup is OK, smooth any runs. TUF SHINE Black Restore is permanent, unlike most trim restorers. Wipe any residue from wheels and/or painted surfaces before it dries. Rinse the applicator sponge with water for future use. 6 oz.
The Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum could be the last vacuum you will ever purchase! With its powerful 2-stage, 2.5 peak HP motor, the Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum provides the powerful suction power to clean up any spill ? wet or dry ? in your auto?s interior. The Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum includes a host of essential accessories to make vacuuming your vehicle, garage or work shop quick and easy. Whether you?re a professional detailer that needs the best or if you?re simply a home owner that desires the best, the Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum will be quickly become a staple in your arsenal of detailing supplies. With its multi-surface claw tool, round brush, and 16 inch crevice tool, the Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum will make cleaning every nook and cranny possible. Combine those features with the generous 35 foot power cord and 12 ft. Lock-On, crush resistant, flexible hose, and you?ll quickly realize that the Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum is in a league of its own. The Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum leaves lesser vacuums in the dust because it features 90 inches of sealed pressure, or lift. Sealed pressure is important because it?s the measure of how far a vacuum motor can lift a column of water up a glass tube. At 90 inches, the Detailer?s 2.5 Peak HP Wet/Dry Auto Detailing Vacuum has more than enough power to clean up virtually any mess, wet or dry. The Detailer?s 8 Gallon 2.5 Peak HP Wet/Dry Auto Detailing Vacuum will also impress you with its super quiet, 2-stage, 2.5 peak HP motor. A 2-stage motor provides a longer operating life and quieter operation compared to traditional single-stage motors. All of the included accessories can be stored onboard the vacuum and the 12 ft. Lock-On crush resistant hose can be removed and coiled up when not in use. Wheels make the vacuum easy to maneuver and the onboard tank drain means you never have to lift the vacuum to empty it of liquid. Specs 2-Stage Motor Cord Length: 35 Feet Operation Sound Level: Super Quiet Hose Size: 1.5" Diameter, 12' Long Warranty: 1 Year Tank Drain Lock-on Hose Onboard Accessory Storage Air Flow: 185 (CFM) Sealed pressure: 90 inches Electrical Rating: 120V 60Hz 9.7Amps Peak Air Watts: 375 Accessories 1.5" dia. x 12' Lock-On, Crush-Resistant Hose Claw nozzle 16" crevice tool Round brush Filters Ultra Web® Cartridge provides 5 times the filtration performance as the standard filter combined with a 2-ply Collection Bag to provide better filtration performance.
StopTech Front 13 Inch 4 Piston Big Brake Kit Mercedes CClass W202 9900 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Mercedes CClass W202 9900 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Rear 13 Inch 4 Piston Big Brake Kit Porsche 997 Carrera 2 05 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit Chevrolet Avalanche 1500 0205 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 15 Inch 6 Piston Big Brake Kit Dodge Challenger SRT8 0809 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Dodge Charger SXT RT 0609 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 13 Inch 4 Piston Big Brake Kit Infiniti G35x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
StopTech Front 14 Inch 4 Piston Big Brake Kit Infiniti G35x AWD 0509 StopTech Big Brake Kits give your vehicle that Supercar look and feel and exceed stock brake system performance in two areas First larger rotors increase heat capacity A brake systems biggest enemy is heat A brake system with inadequate heat capacity will overheat leading to brake fade increased stopping distances and possible failure Second stiffer calipers and stainless steel lines reduce system compliance and increase initial bite and pedal feedback The key is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio If the brake upgrade you select adds too much front torque as many do you reduce your car39s ability to utilize the tractive capacity of all four tires even on ABS equipped cars therefore sacrificing performance In addition too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate which limits a driver39s control of brake input on the race trackStopTechs brake kits offer many advantages over stock systems such asShorter Stopping DistancesBetter Brake ModulationFirmer Brake Pedal feelLess Brake FadeIncreased pedal feedbackStopTech Big Brake Kits include the followingCalipers2 Piece Floating directional AeroRotersStainless Steel Brake LinesStreet performance padsCaliper mounting BracketsPlease remember that unless otherwise noted Big Brake kits will not clear stock wheels StopTech Big Brake Kits come with slotted rotors but for an extra 100 are available with drilled rotorsDrilled brake rotors increase surface area of the brake rotor allowing better airflow and cooling during while the brake system is stressed decreasing brake fade Drilled rotors also give your vehicle a unique exotic look Slotted rotors follow the same principle Grooves machined into the rotor surface allow hot gas water and debris to escape ensuring proper contact in extreme situations as well as increasing the initial bite of the brake system StopTech Big Brake Kit Calipers are available painted Red Black or Silver Please specify rotor type and color upon ordering Trophy Sport Caliper Option IncludesForged Aluminum Calipers Natural anodized finishes on the hat and caliper Color filled StopTech engraved logo StopTech Performance Street pads included Dust Boots in caliper Standard antirattle rotor mounting hardware
