Buy "brake pads" online - search for the best price - compare prices
Recent searches:
full exhaust 1988 conquest air bo fuel level unit brake pads full exhaust conque fuel injectors mitsu engine block 145 inch ssbc rotors f1987 conquest engin air dam conquest intake pipe fuel injectors dana 30 ring and pin head light switch wheels
Page (6465 of 6466) | | 6461 6462 6463 6464 6465 6466 | |
Special Notes: The Vacuum Pump Relocation Kit is Required for Installation on 2012 Model Jeep JK's OR-FAB Front Stubby Bumper with Hoop & Center Winch Mount, Wrinkle Black Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: OR-Fab's Jeep JK steel plate bumpers are handcrafted in the U.S.A. and are constructed from quality 3/16" steel plate to provide superior body protection. We use high tech, precision lasers to cut out the bumpers, and meticulously form them into shape using CNC Press Brakes. Finally the bumpers are hand welded and ground for the utmost quality, before being powder coated for ultimate durability. Our bumpers utilize a tapered design to easily slide off large rocks and ledges making your vehicle ready for the toughest off-road adventures. Designed by off-road enthusiasts, for off-road enthusiasts, these bumpers incorporate everything Jeep owners want in ultimate trail protection and function. All OR-Fab Jeep JK bumpers bolt directly to the factory location without the need for cutting, drilling or welding, and easily mount to the factory location using 1/2" thick steel mounting brackets and high quality stainless steel hardware. OR-Fab's JK bumper #83222 is a steel-plate design that's excellent for maximizing articulation and departure angles with over-sized tires. This bumper features a 2-inch diameter, .120 wall steel tube hoop and integrated center winch mount and 1/4" winch mount plate. The bumper and hoop allows maximum airflow to the radiator and comes with 3/4" Heavy Duty reinforced D-ring mounts and shackles for increased recovery options. Product Features: 3/16" thick steel plate construction Made in the U.S.A. Hand Welded and Grinded for quality Precision LASER cut CNC Press Brake Formed Bolts directly into factory location No need for cutting, drilling or welding 1/2" thick steel mounting brackets Stainless steel hardware Stubby design maximizes tire clearance and approach angles Tapered design easily slides off large rocks and ledges Resessed Winch mount with 1/4" winch mounting plate included Heavy Duty reinforced D-ring mounts and shackles included *Handling Surcharge of $9.99 applies* Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Pinnacle Black Onyx Tire Gel provides a remarkable rich deep black finish that is the perfect compliment to any finely detailed vehicle. The advanced polymer formula is engineered to last and last. Treated tires will retain that rich black finish for 2-3 weeks even through a couple of washings. Pinnacle Black Onyx Tire Gel is specifically engineered to minimize ?sling-off? and add to the longevity of your tires. With ZERO petroleum distillates, butyls or butyl alcohols to damage the environment, our VOC-compliant formula is water based to be gentle on the environment. It is 100% biodegradable. If you like that lasting glow and showroom shine - Warning Pinnacle Black Onyx Tire Gel can be habit-forming! This is a rich thick, high viscosity gel formula that clings to the tire surface. This allows it to penetrate and revitalize the rubber. Liquid dressings rinse off at the first splash of a puddle or drop of rain. They never penetrate the surface. Pinnacle Black Onyx Tire Gel is specially formulated to reach beneath the surface and hydrate the rubber to keep it supple, flexible, and black. The hydrating gel actually combats aging, and prevents the drying, cracking, and fading associated with butyls and petroleum based distillates. Flexible supple rubber is less likely to blow out or tear. Once applied to your tires, Pinnacle Black Onyx Tire Gel clings as it bonds and penetrates the rubber. The hybrid polymer emulsion used in this remarkable formula resists water and detergents. Splashing through puddles and soapy detergent washings, it retains that quality finish. During our testing under strenuous conditions, the finish was retained more than 2 weeks. Our design criteria for Pinnacle Black Onyx Tire Gel went beyond cosmetics. First it must retain its beauty longer and second, add life to your tires. Our chemists produced a product that protects the tires as much as it beautifies. Pinnacle Black Onyx Tire Gel creates a polished rich, natural satin finish on your tires. We were determined to achieve a long lasting, semi-gloss formula because tires should accentuate the car?s finish, not compete. However, if you prefer a glossier finish, it can be layered to achieve a spectacular glistening shine. Pinnacle Clear Coat Safe Wheel Cleaner penetrates brake dust and grime. After drying the wheel, apply Pinnacle Black Onyx Tire Gel as a finishing touch. Directions: Rinse your wheels with water, one wheel at a time. Spray a light mist of Pinnacle Clear Coat Safe Wheel Cleaner over the entire wheel and tire surface. Agitate with a wheel brush and rinse thoroughly. Dry with a Cobra Microfiber Towel to prevent water spots. NOTE: Do not use a tire/wheel towel on your paint. Now your ready for the finishing step with Pinnacle Black Onyx Tire Gel. Once the tire is totally clean, apply a
TeraFlex 3" ENDURO LCG Suspension Lift Kit with VSS 9550 Shocks
TeraFlex 3" ENDURO LCG Suspension Lift Kit with VSS 9550 Shocks Fits: 1997-2006 Jeep Wrangler TJ & Rubicon Model Special Note: Maximum Tire Size: 33" Product Overview: The TeraFlex 3" ENDURO LCG Suspension Lift Kit with VSS 9550 Shocks is designed for the entry-level off-road enthusiast that wants suspension performance with very little modification to the vehicle frame. The ENDURO Long Arm System will transform your current Wrangler's handling capabilities both on and off road. The re-designed long arm bracketry allows for easy installation and access to the transfer case without disassembly of suspension components. Kit Includes: 2 Front VSS 9550 Shocks 2 Rear VSS 9550 Shocks 2 Front Coil Springs 2 Rear Coil Springs 2 Front Sway Bar Disconnects 2 Front Bump Stops 2 Rear Bump Stops 2 Front Brake Line Relocation Brackets 2 Rear Sway Bar Links 2 Lower Long Arms 2 Long Arm Subframe Brackets 2 Rear Lower Shock Relocation Brackets 2 Rear Upper Adjustable Monster Control Arms Steering Box Skid Plate 1 Front Adjustable Track Bar Pitman Arm Kit Specifications: Installation Difficulty: Difficult Installation Time: 14-18 hours on average Features: Low center of gravity with maximum ground clearance Increased highway handling and maneuverability Allows suspension travel for off-road articulation HD 1.75" DOM FlexArm Tubing for superior strength HD Monster Rod Ends for strength, adjustability and customization Special Note: Oversized Package: MUST BE SHIPPED USING FREIGHT TRUCK ONLY! Notes: 1- Full wheel alignment needed 2- CV Style Driveshaft and HD or Extreme Short Shaft SYE Kit recommended 3- CV Style Drive Shaft and Extreme Short Shaft SYE Kit Recommended 4- Rubicon Models add Compressor Mount Plate, TF-4847400 5- Some welding required. 6- If using stock wheels and tires over 32" in diameter, wheel spacers are required to allow unobstructed turning 7- Rubicon Models add 1" Body Lift, TF-1942100 or TF-1900100, to lower the bellyup plate to allow room for the transfer case 8- Transfer Case Lowering Kit recommended for short wheelbase Rubicons Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
LoD Signature Series Shorty Rear Bumper with Generation 3 Tire Carrier, Zinc Coating
LoD Signature Series Shorty Rear Bumper with Generation 3 Tire Carrier, Zinc Coating Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: All New!! This Tire Carrier system is linked to the rear door. You simply open your rear door as you normally would and the carrier system follows the door. When you shut the door the link arm pulls the carrier into the door for a secure and rattle-free set-up! This system is linked to the rear door to provide ease of access to the rear of your vehicle. This system is designed to carry a High-Lift jack as well as any of the three styles of gas can mounts we offer. The Gas can mounts will only be available for the passenger side of this system. The Fullwidth Signature Series Rear bumper is constructed of a combination of 10 gauge, 3/16", and 1/4" steel. The bumper is designed to fit the rear of the Jeep and match right up to the stock factory fender flares. This bumper incorporates an integrated 2" receiver that bolts directly into the rear cross-member of the frame. The bumper also comes standard with two fully welded shackle mounts that accept 3/4" shackles with up to a 7/8" pin. We also provide an optional light kit that includes two (2)-55 watt halogen lights with wiring and a switch. The bumper comes standard with provisions for bolting in the lights we provide with the optional kit. Watch the video to see the strength of this bumper and the protection it will provide! Product Features: CNC Laser Cut for Precision Fitment Protective Plastic positioned at metal contact points to eliminate powder coating wear and rust Tire Carrier is Linked Directly to Rear Door Adjustable Jerry Can mounting Height Adjustable Contact Points for closed position Adjustable Tire Mounting Height Capable of carrying a PowerTank (Passenger Side Mounting Only) Holds up to 37" spare tire (Limited to 37" spare due to strength of factory door latch) Available with a two (2) stage Zinc Enriched Primer Powder Coating Capable of carrying many different configurations of RotoPax Gas Cans (2 and 3 gallon) Capable of carrying Blitz style Jerry Cans (Mount now includes over the can steel strap) Includes Mounting Provisions for High-Lift jacks (Easily accessible w/o removing tire) Includes Mounting bracket for CB Antenna Carrier System designed to prevent water and trail debris build-up Optional adjustable 3rd Brake Light mount attaches directly to the rear door Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
LoD Signature Series Shorty Rear Bumper with Generation 3 Tire Carrier, Textured Black
Price: 1095.99
LOD Signature Series Shorty Rear Bumper with Generation 3 Tire Carrier, Textured Black Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: All New!! This Tire Carrier system is linked to the rear door. You simply open your rear door as you normally would and the carrier system follows the door. When you shut the door the link arm pulls the carrier into the door for a secure and rattle-free set-up! This system is linked to the rear door to provide ease of access to the rear of your vehicle. This system is designed to carry a High-Lift jack as well as any of the three styles of gas can mounts we offer. The Gas can mounts will only be available for the passenger side of this system. The Fullwidth Signature Series Rear bumper is constructed of a combination of 10 gauge, 3/16", and 1/4" steel. The bumper is designed to fit the rear of the Jeep and match right up to the stock factory fender flares. This bumper incorporates an integrated 2" receiver that bolts directly into the rear cross-member of the frame. The bumper also comes standard with two fully welded shackle mounts that accept 3/4" shackles with up to a 7/8" pin. We also provide an optional light kit that includes two (2)-55 watt halogen lights with wiring and a switch. The bumper comes standard with provisions for bolting in the lights we provide with the optional kit. Watch the video to see the strength of this bumper and the protection it will provide! Product Features: CNC Laser Cut for Precision Fitment Protective Plastic positioned at metal contact points to eliminate powder coating wear and rust Tire Carrier is Linked Directly to Rear Door Adjustable Jerry Can mounting Height Adjustable Contact Points for closed position Adjustable Tire Mounting Height Capable of carrying a PowerTank (Passenger Side Mounting Only) Holds up to 37" spare tire (Limited to 37" spare due to strength of factory door latch) Available with a two (2) stage Zinc Enriched Primer Powder Coating Capable of carrying many different configurations of RotoPax Gas Cans (2 and 3 gallon) Capable of carrying Blitz style Jerry Cans (Mount now includes over the can steel strap) Includes Mounting Provisions for High-Lift jacks (Easily accessible w/o removing tire) Includes Mounting bracket for CB Antenna Carrier System designed to prevent water and trail debris build-up Optional adjustable 3rd Brake Light mount attaches directly to the rear door Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Poison Spyder Rocker Knocker with Slider for TJ Flare Pair, Bare Steel
Drilling requiredThe side mounted body bushing must be shortened by 3/16" to accomodate the rocker Poison Spyder Rocker Knocker with Slider for TJ Flare Pair, Bare Steel Fits: 1987-1995 Jeep Wrangler YJ 1976-1986 Jeep CJ7 Product Information: Poison Spyder Rocker Knockers are the ultimate protection for your Jeep's vulnerable rocker panel area. As the trails get tougher and recreational off-roading gets more and more hardcore, vehicle body damage becomes more prevalent. And rocker panels are most vulnerable, taking hits from both underneath and the sides as you work your way through tight obstacles. Poison Spyder Rocker Knockers protect your rocker panels by cladding them in rugged, high strength 3/16" plate steel armor. Rocker Knockers are manufactured to hug the lines of your Jeep's rocker panels perfectly, forming a glove-fit with virtually no loss of valuable ground clearance. Specifically engineered for most Jeep CJ, YJ, TJ and LJ models, Rocker Knockers are CNC laser cut from high strength 3/16" plate steel, and precisiion brake-formed for a perfect fit. Bolt holes are countersunk for the included stainless steel flat head hardware, which yields a flat, unobstructed surface to slide over obstacles. All mounting hardware is included as well as detailed installation instructions. Poison Spyder Rocker Knockers bolt to your Jeep's body in key areas, and interface with strenghtened areas of the underside of the tub such as body mounts, strenthening ribs, etc. Because they mount to the body itself, there is no resulting gap or misalignment when a body lift is installed. For added side protection on the trail, these Rocker Knockers come with a tubular Slider. The Slider is crafted of high strength DOM structural tubing, welded to the Rocker Knocker with additional DOM tube spacers. The result is a combination of rocker panel protection and a tubular slider to keep your rig's bodysides a few precious inches away from taller rocks and trees. The Slider may also become an integral part of your driving strategy, as it may be useful to pivot the vehicle around obstacles while searching for traction. It also serves as a short entry step, assisting entry and egress. For installations in which you would like to protect the paint underneath the Rocker Knocker, as well as provide a measure of vibration absorption, we offer Rubber Rocker Liners, precisely cut to fit between the Rocker Knocker and the Jeep's body. Be sure to order these separately, as they're not included in the standard Rocker Knocker package. Years Covered: 1976, 1977, 1978, 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 and 1995
OR-FAB Front Stubby Winch Bumper With Hoop Fits: 1997-2006 Jeep Wrangler TJ 2004-2006 Jeep Wrangler Unlimited TJL Product Information: OR-Fab's Stubby Bumpers for Jeep TJs are a unique design that add function, maximize approach angles, and provide superior trail protection. These steel plate bumpers are handcrafted in the U.S.A. and are constructed from quality 3/16-inch steel plate to provide superior body protection. We use high-tech precision lasers to cut out the bumpers, then meticulously form them into shape using CNC Press Brakes. Finally the bumpers are hand welded and ground for the utmost quality before being powder coated for ultimate durability. Our bumpers feature a tapered design to easily slide off large rocks and ledges, making your vehicle ready for the toughest off-road adventures. Designed by off-road enthusiasts, for off-road enthusiasts, OR-Fab bumpers incorporate everything Jeep owners want in ultimate trail protection and function. All OR-Fab Jeep TJ bumpers bolt directly to the factory location without the need for cutting, drilling or welding and easily mount to the factory location using 1/2-inch thick steel mounting brackets and high quality stainless steel hardware. OR-Fab's TJ bumper features a 1 3/4-inch diameter winch-guard loop. The bumper includes two 3/4-inch D-ring mounts, D-rings, a heavy-duty winch and fairlead mount, and a sturdy jacking point for Hi-Lift jacks. To top it off, this bumper is available in a Textured Wrinkle Black or a Gloss Black powder coat finish providing good looks and outstanding durability. Product Features: 3/16" thick steel plate construction Made in the U.S.A. Hand Welded and Grinded for quality Precision LASER cut CNC Press Brake Formed Bolts directly into factory location No need for cutting, drilling or welding 1/2" thick steel mounting brackets Stainless steel hardware Stubby design maximizes tire clearance and approach angles Tapered design easily slides off large rocks and ledges Resessed Winch mount with 1/4" winch mounting plate included Heavy Duty reinforced D-ring mounts and shackles included Available in Textured Wrinkle Black or Gloss Black powder coat finish Jeep Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
Maximize prevenetative maintenance for your paint?s finish with the CarPro Paint Decontamination Kit. CarPro Iron X and Tar X make it simple to remove paint-marring contaminants, like iron, tar, bugs, and asphalt. It is as easy as washing your car, maybe easier! The CarPro Paint Decontamination Kit should be used before applying Cquartz or any paint protection to ensure the strongest bond with the paint and the clearest finish. The CarPro Paint Decontamination Kit includes: 500 ml. CarPro Iron X Spray Iron X by CarPro is an acid-free, pH-balanced iron remover that decontaminates auto paint and wheels. Iron X prevents the spread of iron-related damage to protect your vehicle from paint system failure. Iron X is a clear solution in the bottle but it turns purple when it comes into contact with sintered iron particles. 500 g. CarPro Iron X Paste Iron X Paste has a long dwell time to work as long as needed to remove iron and brake dust spots. The paste formula is excellent on vertical panels, wheels, and isolated spots. 600 ml. CarPro Tar X Tar X safely lifts grease, tar, asphalt, insects, tire marks, adhesives, traffic film, and any other stubborn contaminants. There are no harsh chemical solvents and nothing to harm your vehicle. When Tar X is applied generously, it glows on dark or black cars. The visibility makes it easy to remove all of Tar X when rinsing. Lake Country Foam Car Wash Sponge This thick, ultra porous wash sponge is cross-cut with channels to pull dirt away from the paint as you wash your car. The foam is cut into cubes that agitate the paintwork to help release ferrous particles. 3 Microfiber Detailing Towels 16 x 16 inches Use these microfiber detailing cloths for drying, buffing, or as a finishing wipe down. Microfiber is designed to be light, strong, super-absorbent and quick drying. The fibers are non-abrasive, and are woven so tightly that it?s absolutely lint free and extremely durable. Unbelievably, these ultra-tough fibers are engineered to absorb seven times their weight in moisture. 6 Poly Foam Applicators The foam wax applicators can apply any wax evenly without creating any swirl marks. They are absorbent in order to catch drips or runs, and they apply perfect, even coats of paste waxes and polishes. With the CarPro Paint Decontamination Kit, you never have to worry about sealing in harmful contaminants under a coat of wax. This kit deep cleans the paint to protect it and enhance its shine. Kit includes: 500 ml. CarPro Iron X Spray 500 g. CarPro Iron X Paste 600 ml. CarPro Tar X Lake Country Foam Car Wash Sponge 3 Microfiber Detailing Towels 16 x 16 inches 6 Poly Foam Applicators A total retail value of $87.94, save $17.95!
Tuffy Security Products Series II Security Full Console Charcoal
Tuffy Security Products Series II Security Full Console Charcoal Fits: 1997-2000 Jeep Wrangler TJ 2001-2006 Jeep Wrangler TJ (Without Factory Subwoofer) 2004-2006 Jeep Wrangler Unlimited TJL (Without Factory Subwoofer) Important Information: When ordering multiple Tuffy Security Products, you may request to have all products keyed to have matching keys. The Key ALike Service option makes it easy to get into all your Tuffy Products with 1 key, this is done at the Tuffy Products Factory at time of order. 2 Tuffy Products Key Alike # 088-002 3 Tuffy Products Key Alike # 088-0022 4 or more Please Call 877-553-5337 Product Information: This high security 16-gauge steel console enjoys all the same features as the TJ Stereo Security Console except it incorporates two oversized drink holders in place of the separate stereo compartment. The front drink holders, padded armrest, and front console for levers are included in this model. The new sleek, custom fit design matches the TJ's refined interior and offers more interior storage. Features: Patented Pry-Guard II locking system with a 1/4" steel latch which enables the lid to be latched closed without locking Added Security with Pin-Lock Design Patented Anti-twist Push Button Lock System with a 10 tumbler double bitted security key containing Built in Weather Seals Marine grade vinyl padded arm rest Weather resistant lid design incorporates an exclusive hinging system with built-in lid stop Removable shelf Grade 8 mounting hardware provided Durable texture powder coat finish Oversized drink holders with anti-rattle rubber drink fingers Front console for levers & airbag switch Exterior Dimensions: 36"L, 13"W, 17"H, 3 1/2" Holes for drinks Interior Dimensions: (Length is Tapered) 11 1/2"L, 8"W, 14"H (some interior space is lost to parking brake) Mounting: Mounts to factory holes, some drilling required. Airbag disable switch is re-installed in front conset on some years. In 2001 or newer TJs a rear drinkholder Part# 070-03 may have to be purchased to cover cutout in carpet. If any suspension or body lift modification has been done to the vehicle which affected the height of the shift lever the lever will have to be modified. Accessories: Part #070-03, 9 Degree rear drink holder Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
Tuffy Series II Full Security Console Black
Tuffy Series II Full Security Console Black Fits: 1997-2000 Jeep Wrangler TJ 2001-2006 Jeep Wrangler TJ (Without Factory Subwoofer) 2004-2006 Jeep Wrangler Unlimited TJL (Without Factory Subwoofer) Important Information: When ordering multiple Tuffy Security Products, you may request to have all products keyed to have matching keys. The Key ALike Service option makes it easy to get into all your Tuffy Products with 1 key, this is done at the Tuffy Products Factory at time of order. 2 Tuffy Products Key Alike # 088-002 3 Tuffy Products Key Alike # 088-0022 4 or more Please Call 877-553-5337 Product Information: This high security 16-gauge steel console enjoys all the same features as the Jeep Wrangler TJ Stereo Security Console except it incorporates two oversized drink holders in place of the separate stereo compartment. The front drink holders, padded armrest, and front console for levers are included in this model. The new sleek, custom fit design matches the Jeep Wrangler TJ's refined interior and offers more interior storage. Features: Patented Pry-Guard II locking system with a 1/4" steel latch which enables the lid to be latched closed without locking Added Security with Pin-Lock Design Patented Anti-twist Push Button Lock System with a 10 tumbler double bitted security key containing Built in Weather Seals Marine grade vinyl padded arm rest Weather resistant lid design incorporates an exclusive hinging system with built-in lid stop Removable shelf Grade 8 mounting hardware provided Durable texture powder coat finish Oversized drink holders with anti-rattle rubber drink fingers Front console for levers & airbag switch Exterior Dimensions: 36"L, 13"W, 17"H, 3 1/2" Holes for drinks Interior Dimensions: (Length is Tapered) 11 1/2"L, 8"W, 14"H (some interior space is lost to parking brake) Mounting: Mounts to factory holes, some drilling required. Airbag disable switch is re-installed in front conset on some years. In 2001 or newer Jeep Wrangler TJs a rear drinkholder Part# 070-01 may have to be purchased to cover cutout in carpet. If any suspension or body lift modification has been done to the vehicle which affected the height of the shift lever the lever will have to be modified. Accessories: Part # 070-01, 9 Degree rear drink holder Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
Tuffy Security Products Series II Security Full Console Dark Slate
Tuffy Security Products Series II Security Full Console Dark Slate Fits: 1997-2000 Jeep Wrangler TJ 2001-2006 Jeep Wrangler TJ (Without Factory Subwoofer) 2004-2006 Jeep Wrangler Unlimited TJL (Without Factory Subwoofer) Important Information: When ordering multiple Tuffy Security Products, you may request to have all products keyed to have matching keys. The Key ALike Service option makes it easy to get into all your Tuffy Products with 1 key, this is done at the Tuffy Products Factory at time of order. 2 Tuffy Products Key Alike # 088-002 3 Tuffy Products Key Alike # 088-0022 4 or more Please Call 877-553-5337 Product Information: This high security 16-gauge steel console enjoys all the same features as the TJ Stereo Security Console except it incorporates two oversized drink holders in place of the separate stereo compartment. The front drink holders, padded armrest, and front console for levers are included in this model. The new sleek, custom fit design matches the TJ's refined interior and offers more interior storage. Features: Patented Pry-Guard II locking system with a 1/4" steel latch which enables the lid to be latched closed without locking Added Security with Pin-Lock Design Patented Anti-twist Push Button Lock System with a 10 tumbler double bitted security key containing Built in Weather Seals Marine grade vinyl padded arm rest Weather resistant lid design incorporates an exclusive hinging system with built-in lid stop Removable shelf Grade 8 mounting hardware provided Durable texture powder coat finish Oversized drink holders with anti-rattle rubber drink fingers Front console for levers & airbag switch Exterior Dimensions: 36"L, 13"W, 17"H, 3 1/2" Holes for drinks Interior Dimensions: (Length is Tapered) 11 1/2"L, 8"W, 14"H (some interior space is lost to parking brake) Mounting: Mounts to factory holes, some drilling required. Airbag disable switch is re-installed in front conset on some years. In 2001 or newer TJs a rear drinkholder Part# 070-08 may have to be purchased to cover cutout in carpet. If any suspension or body lift modification has been done to the vehicle which affected the height of the shift lever the lever will have to be modified. Accessories: Part #070-08, 9 Degree rear drink holder Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
Tuffy Security Products Series II Security Full Console Light Tan
Tuffy Security Products Series II Security Full Console Light Tan Fits: 1997-2000 Jeep Wrangler TJ 2001-2006 Jeep Wrangler TJ (Without Factory Subwoofer) 2004-2006 Jeep Wrangler Unlimited TJL (Without Factory Subwoofer) Important Information: When ordering multiple Tuffy Security Products, you may request to have all products keyed to have matching keys. The Key ALike Service option makes it easy to get into all your Tuffy Products with 1 key, this is done at the Tuffy Products Factory at time of order. 2 Tuffy Products Key Alike # 088-002 3 Tuffy Products Key Alike # 088-0022 4 or more Please Call 877-553-5337 Product Information: This high security 16-gauge steel console enjoys all the same features as the TJ Stereo Security Console except it incorporates two oversized drink holders in place of the separate stereo compartment. The front drink holders, padded armrest, and front console for levers are included in this model. The new sleek, custom fit design matches the TJ's refined interior and offers more interior storage. Features: Patented Pry-Guard II locking system with a 1/4" steel latch which enables the lid to be latched closed without locking Added Security with Pin-Lock Design Patented Anti-twist Push Button Lock System with a 10 tumbler double bitted security key containing Built in Weather Seals Marine grade vinyl padded arm rest Weather resistant lid design incorporates an exclusive hinging system with built-in lid stop Removable shelf Grade 8 mounting hardware provided Durable texture powder coat finish Oversized drink holders with anti-rattle rubber drink fingers Front console for levers & airbag switch Exterior Dimensions: 36"L, 13"W, 17"H, 3 1/2" Holes for drinks Interior Dimensions: (Length is Tapered) 11 1/2"L, 8"W, 14"H (some interior space is lost to parking brake) Mounting: Mounts to factory holes, some drilling required. Airbag disable switch is re-installed in front conset on some years. In 2001 or newer TJs a rear drinkholder Part# 070-05 may have to be purchased to cover cutout in carpet. If any suspension or body lift modification has been done to the vehicle which affected the height of the shift lever the lever will have to be modified. Accessories: Part #070-05, 9 Degree rear drink holder Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
Poison Spyder Rocker Knocker with Slider Pair, Bare Steel
**Drilling required** Poison Spyder Rocker Knocker with Slider Pair, Bare Steel Fits: 2004-2006 Jeep Wrangler Unlimited TJL Poison Spyder Rocker Knockers are the ultimate protection for your Jeep's vulnerable rocker panel area. As the trails get tougher and recreational off-roading gets more and more hardcore, vehicle body damage becomes more prevalent. And rocker panels are most vulnerable, taking hits from both underneath and the sides as you work your way through tight obstacles. Poison Spyder Rocker Knockers protect your rocker panels by cladding them in rugged, high strength 3/16" plate steel armor. Rocker Knockers are manufactured to hug the lines of your Jeep's rocker panels perfectly, forming a glove-fit with virtually no loss of valuable ground clearance. Specifically engineered for most Jeep CJ, YJ, TJ and LJ models, Rocker Knockers are CNC laser cut from high strength 3/16" plate steel, and precisiion brake-formed for a perfect fit. Bolt holes are countersunk for the included stainless steel flat head hardware, which yields a flat, unobstructed surface to slide over obstacles. All mounting hardware is included as well as detailed installation instructions. Poison Spyder Rocker Knockers bolt to your Jeep's body in key areas, and interface with strenghtened areas of the underside of the tub such as body mounts, strenthening ribs, etc. Because they mount to the body itself, there is no resulting gap or misalignment when a body lift is installed. For added side protection on the trail, Rocker Knockers can be ordered with the optional tubular Slider. The Slider is crafted of high strength DOM structural tubing, welded to the Rocker Knocker with additional DOM tube spacers. The result is a combination of rocker panel protection and a tubular slider to keep your rig's bodysides a few precious inches away from taller rocks and trees. The Slider may also become an integral part of your driving strategy, as it may be useful to pivot the vehicle around obstacles while searching for traction. It also serves as a short entry step, assisting entry and egress. For those who want a more purpose-built entry step, check out Poison Spyder's Ricochet Rockers. For installations in which you would like to protect the paint underneath the Rocker Knocker, as well as provide a measure of vibration absorption, we offer an optional Rubber Liner, precisely cut to fit between the Rocker Knocker and the Jeep's body. Be sure to order these separately, as they're not included in the standard Rocker Knocker package. For Do-It-Yourselfers, we offer the slider tubes by themselves in kit form. With the DIY Slider Tube Kit you can add a rugged, DOM tube slider to your home-built or other manufacturer's rocker protectors. The kit includes the slider tubes as well as the short tube supports to brace the center of the tube against the rocker, to do both sides of the Jeep. We do not recommend welding them to the stock sheetmetal or to steel th
Special Notes: This Product May Not Be Combined With Any Other Offers or Discounts! Warn, M12000 Self-Recovery Winch, Roller Fairlead (12V DC) Fits: All Jeep Models A Reliable Workhorse To Meet Heavy Winching Needs! Product Information: Champion workhorse for heavy-duty winching. 3-stage planetary gear train combined with a 4.6hp series wound motor produce 12,000 lbs. of pulling power. Design is low profile so it fits where you want it. Product Details: Series #: M12000 12,000 lb. (5,440 kg) pulling capacity (single line) Large frame winch design is designed to handle heavier winch loads Series-wound, high-speed motor provides fast line speed and strong pulls Remote-mount control box allows for various mounting options Durable 3-stage planetary geartrain for smooth, reliable, operation Remote control with 12' (3.7m) lead Chip-resistant powder-coated finish 125' of 3/8" (38m of 9.5mm) diameter wire rope Warranty: Lifetime* Winch Dimensions: 24.37" L. x 8.45" D. x 11" H. - (6.19mm L. x 214.63mm D. x 279mm H.) Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm) M12000 SPECS/PART NUMBERS Drum Diameter/Length: 3.5 in /8.2 in (9cm/21cm) Rated Line Pull: 12000 lbs., (5440 kgs.) single-line Motor: Series Wound, 12V 4.6 hp, 24V 2.5 hp Weight (Kit Shipping): 136 lbs. (62kgs.) Electrical Controls: Contactor Wire Rope: 125 ft , 3/8 in diameter (38m, 9.5mm diam.) Remote Control: Remote switch, 12 in (3.7m) lead Fairlead: Roller Geartrain: 3-Stage Planetary Recommended Battery: 650 CCA minimum for winching Gear Ratio: 261:1 Battery Leads: 2 gauge, 72 in. (1.83m) Clutch (Freespooling): Sliding Ring Gear Finish: Argent Gray Powder Coat Brake: Automatic Direct Drive Cone Warranty: Limited Lifetime 24V DC PERFORMANCE SPECS Line PullLbs.(Kgs.) Line SpeedFT./min(M/min.) MotorCurrent Pull by layerlayer/Lbs(Kgs.) 0 31.94(9.57) 24 amps 1/12000 (5443) 2000 (910) 11.7(3.57) 105 amps 2/11120 (5044) 4000 (1810) 9.5 (2.90) 129 amps 3/10340 (4690) 6000 (2720) 8.5 (2.59) 152 amps 4/9770 (4432) 8000 (3630) 7.5 (2.29) 175 amps 5/9250 (4196) 1000 (45400) 6.5 (1.98) 198 amps 12000 (5440) 6.0 (1.83) 221 amps -
Tuffy Security Products Stereo Security Full Console Black
Tuffy Security Products Stereo Security Full Console Black Fits: 1997-2000 Jeep Wrangler TJ 2001-2006 Jeep Wrangler TJ (Without Factory Subwoofer) 2004-2006 Jeep Wrangler Unlimited TJL (Without Factory Subwoofer) Important Information: When ordering multiple Tuffy Security Products, you may request to have all products keyed to have matching keys. The Key ALike Service option makes it easy to get into all your Tuffy Products with 1 key, this is done at the Tuffy Products Factory at time of order. 2 Tuffy Products Key Alike # 088-002 3 Tuffy Products Key Alike # 088-0022 4 or more Please Call 877-553-5337 Product Information: This 16-gauge steel security console has a separate lockable compartment for mounting a stereo or other electronic equipment. The rear compartment provides additional lockable storage for more valuables. The new sleek fit design and retractable stereo compartment lid matches the TJ's refined interior and offers more interior storage. Features: Patented Pry-Guard II locking system with a 1/4" steel latch which enables the lid to be latched closed without locking Added security with Pin-Lock hinge design Patented Anti-twist push button lock system with a 10 tumbler double bitted security key containing Built in weather seals Marine grade vinyl padded arm rest for added comfort Rear oversized drink holders with anti-rattle rubber drink fingers Weather resistant lid design incorporates an exclusive hinging system with built-in lid stop Removable shelf Grade 8 mounting hardware provided Durable texture powder coat finish Stereo mounting compartment with stow-away lid design Front console for levers & airbag switch Exterior Dimensions: 41 1/2"L, 13"W, 17"H, 3 1/2" Holes for drinks Interior Dimensions: Rear Compartment: (Length is Tapered) 11 1/2"L 8"W, 14"H, (Some interior space is lost to parking brake) Stereo Compartment: Comes pre-cut for DIN Mount stereo 7 1/4"L, 2 3/16"W, 7" Depth, 90 Degree Angle (Stereo Not Included) Mounting: Mounts to factory holes, some drilling required. Airbag disable switch is re-installed in front conset on some years. Stereo not included. If any suspension or body lift modification has been done to the vehicle which affected the height of the shift lever the lever will have to be modified. Accessories: Part #150-01, Stereo dash cutout tray Part #151-01, Stereo dash cutout cover Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
When turning heads will not do?.use BLACKFIRE, and create ?whiplash!? The BLACKFIRE Wheel & Tire Kit contains the products and the tools to make your wheels and tires look as polished as the rest of your vehicle. No detail is complete without cleaning the wheels and tires, and these superior products make it easy. BLACKFIRE formulas are the result of over twenty years of research with state-of-the-art polymers from Germany, Sweden and the US. BLACKFIRE waxes and sealants wipe on and buff off easily without streaks or hazy patches and with a shine that can last for six months or more. All BLACKFIRE products are surface-friendly and VOC compliant in all 50 states. These water-based formulas clean, condition, polish and protect without the strong solvents found in most car care products. 20 oz. BLACKFIRE Total Eclipse Tire and Wheel Cleaner BLACKFIRE Total Eclipse Tire & Wheel Cleaner is an advanced, surface-safe formula that cleans painted, chrome, polished aluminum, and anodized wheels. It cleans the most delicate wheel surfaces without staining or dulling wheel finishes. BLACKFIRE Total Eclipse Tire & Wheel Cleaner works just as effectively on tires, releasing brake dust and dirt buildup from the rubber. It?s the only tire and wheel cleaner you need. 16 oz. BLACKFIRE Total Eclipse Tire Gel  BLACKFIRE Total Eclipse Tire Gel darkens and conditions rubber to restore the look of new tires. This thick, water-based tire dressing provides a natural, matte look with one coat or a high gloss finish with two coats. UV inhibitors and polymers protect tires to maintain their color and flexibility. The formula is water-based and solvent-free. BLACKFIRE Total Eclipse Tire Gel provides the concours look that complements any vehicle. 3 Flex Foam Tire Dressing Applicators Cobra Flex Foam Tire Dressing Applicators are made of a unique foam composition that conforms to the curve of your tires? sidewalls. Foam applicators that are precut into a curve might not match the curvature of your vehicle?s particular tires. Cobra Flex Foam Tire Dressing Applicators flex to hug the rubber and apply a neat, even layer of tire dressing. Short handled Green Brush This well-made, indestructible brush is practical, efficient and safe for all wheels. It has hundreds and hundreds of densely packed bristles, feathered at the tip for gentle agitating of any wheel surface, regardless of delicacy. The bristles are sturdy enough to attack tough road grease and grime on your tires as well. The brush is constructed of alkaline- and acid-resistant, 2? fibers, mounted on a non-slip, heavy-duty plastic handle. 2 Microfiber All Purpose & Wheel Detailing Towels Buff your wheels, paint, glass, chrome, and interior surfaces to a brilliant shine with the Microfiber All Purpose & Wheel Detailing Towel! It's paintwork-safe and the black color makes it the ideal towel for cleaning, polishing, and drying wheels. Each Kit conta
Fabtech 6in Performance Lift System with Dirt Logic Shocks wo Auto Ride Chevrolet Avalanche 4WD 0708With an all new platform for 2007 GM Fullsize SUV39s and SUT39s Fabtech has developed multiple systems that provide everything from a stock like ride up to a mega dampening offroad suspension Common to all 2007 GM systems is Fabtech39s legendary one piece high arched lower crossmember design with an integrated differential skid plate for solid support of the front suspension Special attention was given to the design of replacement extended length steering knuckles to keep the track width of the vehicle near stock while retaining turning radius for easy maneuverability in tight areas All rear systems feature extended length tubular upper and lower link arms with an oversized Trac bar relocation bracket to properly place the axle under the vehicle with zero driveline vibration Auto Ride and non Auto Ride specific rear coil springs maintain proper ride height on all models Fabtech39s Performance System provides the Dirt Logic 25 coilover front shocks for superior damping This Performance system will provide a supple highway ride with outstanding offroad damping capabilities for the best of both worlds Installation of all systems does not require relocation of the Rack and Pinion or disassembly of the front strut assemblies There are no brake lines exhaust system welding or driveline modifications required for installationFeatures Benefits Integrated Lower Control Arm Crossmembers includes Differential Skid Plate Offset Ductile Iron Front Steering knuckles retain stock like turning radius with minimal increase of track width No disassembly of factory strut assembly required for installation System compatible with factory Autoride models Rack and Pinion is retained in stock position Full lift height for proper clearance of 351250R17 tires Rear system includes Auto Ride model specific coil springs with upper and lower tubular link arms and trac bar relocation bracketKit Includes FTS21040BK Component Box 1 FTS21041BK Component Box 2 FTS21043BK Dirt Logic 25 Frt Coilovers FTS21052BK Rear Box Kit Dirt Logic Rear FTS81050 Dirt Logic 225 Rear Non ResiNotesWill not fit all wheel drive modelsThis part ships via truck frieght due to the high shipping weight of this product Please add item to cart for shipping cost or contact us for a quote
Truck/Freight May Apply Poison Spyder Trail Cage Kit Fits: 1997-2006 Jeep Wrangler TJ 2004-2006 Jeep Wrangler Unlimited TJL Product Information: The Poison Spyder Trail Cage is designed for those Jeep YJ, TJ and LJ owners who already have the factory roll bar, and would like to add on to it to form a full roll cage rather than installing a complete new cage. The Trail Cage kit is an eight piece set. It comes with two Lower A-Pillars (dash to floor supports) and two tubular Upper A-pillars that are to be welded to the factory windshield bars. Also included are a dash bar, upper windshield bar, and two center spreaders that can be located in several positions. The Poison Spyder Trail Cage kit comes disassembled and requires welding to install. The Lower A-Pillar is designed to provide a strong foundation for the forward section of the cage while not intruding into the dash or compromising legroom. The Trail Cage is secured at the windshield, at the front gusseted A-Pillar, at factory mounts on the door jamb and to the floor through the forward drain hole. This provides solid strength from the top of the windshield to the floor. The Lower A-Pillars and gussets are CNC laser cut and precision brake-formed for quality and fit. Tubular kit components are constructed from 1.75" .120 wall DOM structural tubing. All tubular components are CNC-bent and laser-notched for a precise fit, and laser-marked with reference numbers for easy identification and installation. The Heavy Duty Header Bar Kit PS1418030 is sold separately but is a highly recommended addition to the Trail Cage installation. The Trail Cage can be installed with the stock header bars, but those are little more than thin-wall tubing intended to brace the windshield, providing little in the way of cage protection. Our Heavy Duty Header Bar Kit replaces them with precision-manufactured, high strength components that work withh your stock roll bar and Poison Spyder Trail Cage Kit to provide the strength and safety of a real deal, heavy duty cage. The Heavy Duty Header Bars are made from high strength 1-3/4" X .120 wall DOM structural tubing, laser notched and expertly welded to CNC laser cut 3/16" mount plates. For comparison, the stock header bars are made of .095 wall welded seam tubing, withh thin gauge stamped metal mounting flanges. The DOM tubing used in the Poison Spyder kit has a yield strength of 70,000 psi, with a tensile strength of 44,668 lbs. Compare that to the welded seam tubing of the stock header bars, at 40,0000 psi yield strength and only 19,757 lbs. tensile strength. The Heavy Duty Header Bar Kit may also be installed by itself without the Trail Cage, or with other manufacturer's add-on cage kits. Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
Detailing clay sets the stage for a dramatic Wet Diamond shine! This is a complete wash-clay-polish-protect kit for all types of paint. Use the BLACKFIRE Exterior Kit for a clear, deep shine that glistens like a wet diamond! BLACKFIRE formulas are the result of over twenty years of research with state-of-the-art polymers from Germany, Sweden and the US. BLACKFIRE waxes and sealants wipe on and buff off easily without streaks or hazy patches and with a shine that can last for six months or more. All BLACKFIRE products are surface-friendly and VOC compliant in all 50 states. These water-based formulas clean, condition, polish and protect without the strong solvents found in most car care products. 7.4 oz. BLACKFIRE Midnight Sun Ivory Carnauba Paste Wax BLACKFIRE Midnight Sun Ivory Carnauba Paste Wax brings out the best in all paint finishes with a combination of super-refined carnauba wax blended with nourishing oils and German polymers. This wax creates incredible depth of shine on all paint colors with a hard, protective barrier to the elements. BLACKFIRE Midnight Sun Ivory Carnauba Paste Wax is perfect on top of Blackfire Wet Diamond All Finish Paint Protection or by itself. It glimmers with depth either way! 16 oz. BLACKFIRE Wet Diamond Conditioning Shampoo BLACKFIRE Wet Diamond Conditioning Shampoo cleans your vehicle and renews the shine with every wash. BLACKFIRE Wet Diamond Polymers replenish and reinforce existing paint protection. Incredible Tuff Suds II technology creates mountains of suds to help float away grime and dirt, without scratching the finish. BLACKFIRE Wet Diamond Conditioning Shampoo helps your vehicle look just waxed after every wash! 16 oz. BLACKFIRE Gloss Enhancing Polish BLACKFIRE Gloss Enhancing Polish visually reduces swirl marks while creating a wet-look shine. It removes old waxes and sealants and cleans the paint's surface to prep it for a shiny coat of wax or paint sealant. BLACKFIRE Gloss Enhancing Polish is a non-abrasive polish and glaze combination. Used before your LSP (last step product), BLACKFIRE Gloss Enhancing Polish improves the gloss and clarity of the finish. 200 gram BLACKFIRE Poly Clay II BLACKFIRE Poly Clay II Bar is a premium, nonabrasive grade of detailing clay that works on all paint finishes, including clear coats. It is easy to work with and leaves almost no residue on the surface of the vehicle. PolyClay does not dry out with age and does not decompose with repeated applications. BLACKFIRE Poly Clay Bar leaves auto paint feeling slick, clean, and silky by removing rail dust, brake dust, industrial fallout, tree sap, and overspray. 20 oz. BLACKFIRE Clay Cleaner & Extender BLACKFIRE Clay Cleaner & Extender allows you to clean the majority of debris off the clay bar to extend its usable life! Special surfactants in this product deep clean the surface of the clay without drying or damaging the clay. By cleaning the detailing clay, you can use the same bar longer without jeopa
Poison Spyder Lazer-Fit Full Cage Kit Bare Steel
Truck/Freight May Apply Poison Spyder Lazer-Fit Full Cage Kit Bare Steel Fits: 1987-1995 Jeep Wrangler YJ Kit Includes: (1) YJ Lower A-Pillar Left & Right (1) YJ Lower A-Piller Inner Plate L&R (2) A-Pillar Top Gusset (2) A-Pillar Foot Plate (2) Main Side Hoop L&R (1) C-Hoop (2) Forward Stringer L&R (2) B-Pillar Mount Plate L&R (1) Seatbelt Bar (1) B-Crossbar (1) Dash Bar (1) A-Crossbar (2) B-Pillar L&R (2) rearward Stringer L&R (2) C-Pillar L&R Product Information: The Poison Spyder Full Cage Kit is a complete, weld-in cage designed with hard core four-wheeling in mind. It represents a combination of maximum functionality and unmistakable Poison Spyder style. Available for most Jeep Wrangler models, the Full Cage Kit comes with every piece of tubing or plate steel component you need to assemble a complete Poison Spyder Full Cage. And there are many options available to customize the cage to your specific needs. All of our Full Cage Kits now feature Poison Spyder's exclusive Lazer-Fit system to ensure precise fit and easy installation. The Lazer-Fit system involves every aspect of the component, from 3-D CAD design to production on state-of-the-art machinery, to easy, worry-free installation by you. The entire assembly is fully engineered in 3-D design software, using an actual 3D model of the specific vehicle to ensure the best fit and use of space. Tubular components are made of high strength structural DOM tubing that is laser-cut, laser-notched and laser-etched to exact tolerances. Then tube pieces are CNC bent for a quality-assured, precise fit. The result is a kit of parts that match and fit each other perfectly, with no need for forther grinding, notching, fitting or cussing. Assembly guides are laser-etched right onto the surface of the tube, precisely denoting where the perfectly notched end of one tube joins the surface of the other. Components are also etched with part identification marks to take all the guesswork out f assembling your cage. Lazer-Fit cuts the assembly time in half (or more!), compared to competitors' and Poison Spyder's previous model cage kits. YJ, TJ and LJ versions of the Full Cage Kit incorporate Poison Spyder's proprietary Lower A-Pillars. The Lower A-Pillar is engineered to provide a strong foundation for the forward section of the cage while not intruding into the dash or compromising legroom. The Lower A-Pillars and gussets, as well as all mounting plates, are CNC laser cut and precision brake-formed from high strength 3/16" plate steel for quality and fit. Spyder Web Cage Gussets are available to provide extra strength and killer looks to your Poison Spyder cage. CNC laser-cut from 3/16" plate steel, these gussets are specially cut to fit behind the B-pillar of the Lazer-Fit cage. Entry Grab Handles may be added to make entry and exit easier, as well as providing a secure grab handle while wheeling. Made of 1.25" X .120 wall tubing, bent and laser notched to perfec
Poison Spyder Full Cage Kit Bare Steel
**TRUCK FREIGHT WILL APPLY** Poison Spyder Full Cage Kit Bare Steel Fits: 1997-2006 Jeep Wrangler TJ Kit Includes: (2) Windshield Mount Plate L&R (2) B-Pillar Mount Plate L&R (2) C-Pillar Mount Plate L&R (2) Lower A-Pillar L&R (2) Main Side Hoop L&R (2) Upper A-Pillar Tube L&R (2) B-Pillar L&R (1) Dash Bar (1) A-Crossbar (2) Forward Stringer L&R (1) B-Crossbar (2) C-Pillar L&R (1) Seatbelt Bar (2) 1/2-13 X 2-1/2 Gr8 Hex Head Cap Screw (2) Washer Plate (2) 1/2-13 Nylon Insert Lock Nut Product Information: The Poison Spyder Full Cage Kit is a complete, weld-in cage designed with hard core four-wheeling in mind. It represents a combination of maximum functionality and unmistakable Poison Spyder style. Available for most Jeep Wrangler models, the Full Cage Kit comes with every piece of tubing or plate steel component you need to assemble a complete Poison Spyder Full Cage. And there are many options available to customize the cage to your specific needs. All of our Full Cage Kits now feature Poison Spyder's exclusive Lazer-Fit system to ensure precise fit and easy installation. The Lazer-Fit system involves every aspect of the component, from 3-D CAD design to production on state-of-the-art machinery, to easy, worry-free installation by you. The entire assembly is fully engineered in 3-D design software, using an actual 3D model of the specific vehicle to ensure the best fit and use of space. Tubular components are made of high strength structural DOM tubing that is laser-cut, laser-notched and laser-etched to exact tolerances. Then tube pieces are CNC bent for a quality-assured, precise fit. The result is a kit of parts that match and fit each other perfectly, with no need for forther grinding, notching, fitting or cussing. Assembly guides are laser-etched right onto the surface of the tube, precisely denoting where the perfectly notched end of one tube joins the surface of the other. Components are also etched with part identification marks to take all the guesswork out of assembling your cage. Lazer-Fit cuts the assembly time in half (or more!), compared to competitors' and Poison Spyder's previous model cage kits. YJ, TJ and LJ versions of the Full Cage Kit incorporate Poison Spyder's proprietary Lower A-Pillars. The Lower A-Pillar is engineered to provide a strong foundation for the forward section of the cage while not intruding into the dash or compromising legroom. The Lower A-Pillars and gussets, as well as all mounting plates, are CNC laser cut and precision brake-formed from high strength 3/16" plate steel for quality and fit. Optional Entry Grab Handles may be added to make entry and exit easier, as well as providing a secure grab handle while wheeling. Made of 1.25" X .120 wall tubing, bent and laser notched to perfectly fit Poison Spyder Lazer-Fit cages. Kit comes with both right and left handles. Securely add a seatbelt mount point to your cage with Poison Spyder's Machined Seatbelt Bungs.
Special Notes: This Product May Not Be Combined With Any Other Offers or Discounts! WARN 9.5cti Contactor Equipped Winch with 125' Wire Rope and Roller Fairlead Fits: Universal Fit Product Information: Contactor equipped, thermometric winch is the newest addition to the WARN Ultimate Performance winch lineup. A massive protective structure combined with sophisticated operator feedback delivers fast line speeds, and long duty cycles. Product Features: New contactor control features exceptional durability, extra long life, and superior weather sealing Series Wound motor and 3-stage planetary gear train deliver 9,500 lbs. of pulling capacity Extreme duty winch sealing system Motor-mounted thermal sensor relays temperature information to winch operator by way of the hand-held remote control with LED indicator Redesigned remote control with thermometric indicator light High gloss, chip-resistant black powder coat finish over a massive cast-aluminum alloy housing Wireless Remote Control System can be added which is also available separately. w76080 9.5cti SPECS/PART NUMBERS Part Number: PN 97550 (12V DC) Rated Line Pull: 9500 lbs. (4310 kgs.) single-line Motor: Gen II, Series Wound Electrical controls: Contactor Remote Control: Remote switch, LED indicator, 12' (3.7m) lead Geartrain: 3-Stage Planetary Gear Ratio: 156:1 Clutch (freespooling): Sliding Ring Gear Brake: Automatic Direct Drive Cone Drum Diameter/Length: 2.5"/9.0" (6.4cm/23cm) Weight: 89 lbs. (36.3kgs.) Wire Rope: 125', 5/16" diameter (30m, 8mm diam.) Fairlead: Roller Recommended Battery: 650 CCA minimum for winching Battery Leads: 2 gauge, 72" (1.83m) Finish: High-gloss black powder coat over primer undercoating 12V DC PERFORMANCE SPECS Line PullLbs.(Kgs.) Line SpeedFT./min(M/min.) MotorCurrent Pull by layerlayer/Lbs(Kgs.) 0 62(18.9) 47 amps 1/9500(4313) 2000(910) 16.3(4.97) 160 amps 2/8650(3927) 2000(910) 16.3(4.97) 160 amps 2/8650(3927) 4000(1810) 11.8(3.60) 230 amps 3/7920(3595) 6000(2720) 9.31(2.84) 305 amps 4/7400(3359) 8000(3630) 7.59(2.31) 370 amps 5/6940(3150) 9500(4310) 6.67(2.03) 425 amps Above performance specs are based on first layer of drum Winch Dimensions: 23.1" L. x 6.3" D. x 10.4" H. (587mm L. x 160mm D. x 264mm H.) Mounting Bolt Pattern: 10.0" x 4.5" (254mm x 114.3mm)
ReadyLift Upper Control Arm Kit 2011-Up Ford F-250/F350 4WD Off Road 5 Lift Kit-Series 3 - 49-2002
Price: 3389.99
The new Ready LIFT Off Road Suspension Series 5" Lift Kit Made To Fit 2011-2013 Ford Super Duty trucks gives owners an excellent lift kit option that will raise both F250 and F350 trucks 5" for maximum tire clearance and unbeatable off road performance. Install up to 38" tall off road tires with no problems. This new off road kit delivers uncompromised ride and handling performance! The Ready LIFT Off Road Suspension 5" Lift Kit is available in three different configurations (Series 1, 2 and 3). The Premium Series 3 2011-2013 Ford Super Duty 5" Lift Kit takes our Series 2 kit to a whole new level of suspension perfection by including our new Super Duty Anti-Wobble Trac Bar for lifted trucks as well as four Ready LIFT SST9000 Performance Shocks! This combination creates the ultimate Super Duty Lift Kit that not only GREATLY improves the ride and driving quality of your truck, but also GREATLY improves the off road ability of the vehicle. We guarantee that if you were to test drive a Super Duty with our Series 3 Lift Kit that you would be absolutely amazed!!!Like the Series 2 kit, the Premium Series 3 kit also includes custom wound coil springs engineered to provide an incredibly great ride while also enhancing off road driving performance. Tabbed and slotted heavy duty boxed steel radius arms with urethane pivots. A mini leaf pack and OEM-style cast iron rear blocks lifts the rear of the truck without compromising towing or hauling abilities and actually helps the rear to ride better than stock. Other great components to this kit include a drop pitman arm, track bar bracket designed specifically for 5 inches of lift, longer, stronger sway bar end links, CNC machined billet aluminum drive shaft spacer, and all hardware is included. Product Features:5" of lift for additional ground clearance and ability to clear up to 38" tires.Tab and slot design of the boxed radius arms increases strength and reliability.SST9000 Performance Shocks - 2.25" CNC Machined aluminum bodies - Rebuildable & Revalvable.Heavy Duty Anti Wobble Trac Bar included to firmly plant your truck in the road or trail.Custom wound coil springs for maximum off road and on road performance.Urethane bushings will last longer and can be greased by a zerk fitting.The rear mini pack adds to the lift and performance of the rear leaf springs.CNC billet drive shaft spacer corrects drive shaft plunge/engagement.Includes? extended sway bar end links, bump stop extensions, alignment cams, drop pitman arm and extended brake line bracketsIncreased Off Road Ability with An Incredibly Great Ride!. Most Lifts & Lowering Kits products are available for in-store pickup from Advance Auto Parts.
ReadyLift Upper Control Arm Kit 2008-2010 Ford F250/F350 4WD Off Road 5 Lift Kit-Series 3 - 49-2005
Price: 3389.99
The new Ready LIFT Off Road Suspension Series 5" Lift Kit Made To Fit 2008-2010 Ford Super Duty trucks gives owners an excellent lift kit option that will raise both F250 and F350 trucks 5" for maximum tire clearance and unbeatable off road performance. Install up to 38" tall off road tires with no problems. This new off road kit delivers uncompromised ride and handling performance! The Ready LIFT Off Road Suspension 5" Lift Kit is available in three different configurations (Series 1, 2 and 3). The Premium Series 3 2008-2010 Ford Super Duty 5" Lift Kit takes our Series 2 kit to a whole new level of suspension perfection by including our new Super Duty Anti-Wobble Trac Bar for lifted trucks as well as four Ready LIFT SST9000 Performance Shocks! This combination creates the ultimate Super Duty Lift Kit that not only GREATLY improves the ride and driving quality of your truck, but also GREATLY improves the off road ability of the vehicle. We guarantee that if you were to test drive a Super Duty with our Series 3 Lift Kit that you would be absolutely amazed!!!Like the Series 2 kit, the Premium Series 3 kit also includes custom wound coil springs engineered to provide an incredibly great ride while also enhancing off road driving performance. Tabbed and slotted heavy duty boxed steel radius arms with urethane pivots. A mini leaf pack and OEM-style cast iron rear blocks lifts the rear of the truck without compromising towing or hauling abilities and actually helps the rear to ride better than stock. Other great components to this kit include a drop pitman arm, track bar bracket designed specifically for 5 inches of lift, longer, stronger sway bar end links, CNC machined billet aluminum drive shaft spacer, and all hardware is included. Product Features:5" of lift for additional ground clearance and ability to clear up to 38" tires.Tab and slot design of the boxed radius arms increases strength and reliability.SST9000 Performance Shocks - 2.25" CNC Machined aluminum bodies - Rebuildable & Revalvable.Heavy Duty Anti Wobble Trac Bar included to firmly plant your truck in the road or trail.Custom wound coil springs for maximum off road and on road performance.Urethane bushings will last longer and can be greased by a zerk fitting.The rear mini pack adds to the lift and performance of the rear leaf springs.CNC billet drive shaft spacer corrects drive shaft plunge/engagement.Includes? extended sway bar end links, bump stop extensions, alignment cams, drop pitman arm and extended brake line bracketsIncreased Off Road Ability with An Incredibly Great Ride!. Most Lifts & Lowering Kits products are available for in-store pickup from Advance Auto Parts.
TeraFlex 5" PRO LCG Suspension Lift Kit with Shocks
TeraFlex 5" PRO LCG Suspension Lift Kit with Shocks Fits: 1996-2006 Jeep Wrangler TJ & Rubicon Model See Special Notes at the bottom of this page: 1, 2, 4, 5, 6, 7 & 8 Special Notes: Maximum Tire Size: 35" Special Note: Oversized Package: MUST BE SHIPPED USING FREIGHT TRUCK ONLY! Product Overview: TeraFlex PRO LCG 5" Suspension Lift Kit is designed for the aggressive off road enthusiast that wants the best suspension performance for both rock crawling and high speed performance. The PRO system allows the vehicle to tackle the toughest rock crawling trails of Moab, and speed on the dunes at Glamis with balanced suspension movement. Features: Low center of gravity with maximum ground clearance 4-Link Rear Upper Geometry Eliminates Rear Trackbar Allows complete suspension travel for full range of motion Rear Anti-Squat Bracketry for fine tuning performance HD 1.75" DOM Lower FlexArm Tubing for superior strength Works perfectly with Engine Conversions (V6, V8, etc.) Designed to work with aftermarket high Pinion Axles Kit Includes: Front VSS 9550 Shocks Rear VSS 9550 Shocks Front Coil Springs Rear Coil Springs Front Sway Bar Disconnects Rear Sway Bar Links Front Bump Stops Rear Bump Stops Front Frame Upper Long Arm Brackets Front Shock Bar Bin Eliminators Front Shock Stud to Eye Conversion Kit Front Track Bar Bracket Front Exhaust Pipe HD Front Adjustable Track Bar Rear Axle Truss Rear Frame 4-Link Brackets Rear Lower Shock Relocation Brackets Lower Long Arms Upper Long Arms Long Arm Subframe Brackets Stainless Steel Brake Lines Steering Box Skid Plate Pitman Arm Kit Specifications: Installation Difficulty: Difficult Installation Time: 23 hours on average Dimensions: Length: 48" Width: 48" Height: 42" Weight: 452 Lbs. Special Notes: 1- Full wheel alignment needed 2- CV style driveshaft and HD or Extreme Short Shaft SYE kit recommended 3- CV style driveshaft and Extreme Short Shaft SYE kit recommended 4- Rubicon models need to add a Compressor Mount Plate, TF-4847400 5- Some welding required 6- If using stock wheels and tires over 32" in diameter, wheel spacers are required to allow unobstructed turning 7- Rubicon Models add 1" Body Lift, TF-1942100 or TF-1900100, to lower the bellyup plate to allow room for the transfer case 8- Transfer Case Lowering Kit recommended for short wheelbase Rubicons Years Covered: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005 and 2006
