Buy "brake pads" online - search for the best price - compare prices
Recent searches:
full exhaust fuel injectors wheels fuel injectors mitsu 1988 conquest air bo full exhaust conque f1987 conquest engin air dam 145 inch ssbc rotors brake pads conquest intake pipe fuel level unit dana 30 ring and pin head light switch engine block
Page (6463 of 6466) | | 6459 6460 6461 6462 6463 6464 6465 6466 | |
Poison Spyder Rear Crusher Corners Pair with LED Tail Lights Cutouts
**Drilling required** Poison Spyder Rear Crusher Corners Pair with LED Tail Light Cutouts Fits: 2007-2013 Jeep Wrangler Unlimited JK Product Information: Poison Spyder Crusher Corners for the Jeep Wrangler Unlimited JK provide ultimate protection for the vulnerable rear corners of your Jeep Wrangler Unlimited JK. Crusher Corners are full-corner protectors, extending from the rear tailgate, around the side, over the wheel openings and all the way to the door openings. Made of rugged 1/8" steel, Jeep Wrangler Unlimited JK Crusher Corners may be used with the stock Jeep Wrangler Unlimited JK fender flares or with Poison Spyder's Jeep Wrangler Unlimited JK Rear Crusher Flares for the ultimate combination of rear corner armor. Poison Spyder Jeep Wrangler Unlimited JK Crusher Corners are unique among aftermarket corner armor, in that they provide full coverage while conforming to the compound curves and subtle contours of the Jeep Wrangler Unlimited JK body lines. Competitors' full corner protectors are brake-formed from flat steel, and may require the removal of large swaths of the stock sheetmetal in order to install them. Poison Spyder Crusher Corners are tool-formed to match the Jeep Wrangler Unlimited JK body lines in a close-fitting overlay, requiring no cutting of the body except to clearance for the flush-mount LED lights (on LED-ready versions). Jeep Wrangler Unlimited JK Crusher Corners come in a complete kit with stainless steel button head hardware. Drilling is required, as is installation of threaded "nut-serts" (Poison Spyder provides the nut-serts, a simple nut-sert installation tool and detailed instructions). Jeep Wrangler Unlimited JK Crusher Corners are shipped as bare steel. Jeep Wrangler Unlimited JK Crusher Corners are available with several taillight provisions: Blank has no taillight cutouts, for those doing custom fabrication; LED for use with a flush mount 4" high intensity LED taillight PS-4104050; and for LED Taillights PS-4104036. When installing LED taillights in the Jeep Wrangler Unlimited JK, we recommend using the LED Resistor Kits PS-4104650 sold separately. These will correct the current in your Jeep Wrangler Unlimited JK's electrical system for proper functioning of the LED's. They are sold by each, two are needed for one Jeep. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Superwinch Talon 9.5i SR-9,500 lbs/12V Universal Fit Product Overview: Superwinch synthetic ropes are genuine AmSteel-Blue with Samthane, a special coating to help resist abrasion. The raw material in AmSteel-Blue is made from genuine Dyneema SK-75 HMPE fiber, "which is the worlds strongest fiber" made by Sampson Rope Technologies. AmSteel-Blue is a torque-free 12-strand single braid that yields the maximum in strength-to-weight ratio and, size for size, is the same strength as steel"yet it floats. AmSteel-Blue outlasts wire 3:1, making it an excellent wire rope replacement. It has extremely low stretch and superior flex fatigue and wear resistance. Average strength is 19,600 lbs. and minimum strength is 17,600 lbs. Elastic elongation is only 0.96% at 30% of the break strength. Product Details: Rated Line Pull: 9,500 lbs (4,309 kgs) Motor: Sealed 5.2 hp (3.8 kw) Series Wound Gearing: 2-Stage Planetary and 2-Stage Spur Gear Ratio: 148:1 Solenoid: Vented, Sealed Submersible Solenoid with 3-Year Warranty Clutch: Free-spooling Clutch/Pull and Turn Brake :Automatic/100% Load Holding (outside of drum) Rope: Synthetic Rope 3/8 x 80 (9.5mm x 24.4m) Hook: Heavy Duty/Clevis Pinned/Latched Fairlead: Anodized Blue Aluminum Hawse with Engraved Superwinch Logo Remote: 15' Sealed Ergonomic Hand-held with Coiled Cord Dimensions: 24.22 L x 6.20 D x 10.66 H (615.20mm L x 157.50mm D x 270.75mm Drum Diameter: 2.5 (63.5mm) Drum Length: 8.75 (222.2mm) Mounting Bolt Pattern: 10 x 4.5 (254mm x 114.3mm) Installed Weight: 67 lbs (30 kgs) Shipping Weight: 80 lbs (36 kgs) Warranty: Limited Lifetime Warranty/3-Year Electrical UPC: 0 22705 16915 8 Line Pull: 0 lbs 75 Amps Motor Draw / 62 FPM (18.9 MPM) Line Speed Line Pull: 9,500 lbs 430 Amps Motor Draw / 5.0 FPM (1.5 MPM) Line Speed
UltraShine Aluminum 3 Inch round Side Steps UltraShine Aluminum; Side Steps; Universal 3 in. Round; 2 Step Pads; 64 inchesSold as a pair CHEVROLET DODGE FORD GMC TOYOTA C1500 PICKUP C20 PICKUP C2500 PICKUP C30 PICKUP C3500 PICKUP D100 PICKUP D150 PICKUP D200 PICKUP D250 PICKUP D300 PICKUP D350 PICKUP F-100 PICKUP F-150 HERITAGE PICKUP F-150 PICKUP F-250 PICKUP F-350 PICKUP K1500 PICKUP K20 PICKUP K2500 PICKUP K30 PICKUP K3500 PICKUP RAM 1500 PICKUP RAM 2500 PICKUP RAM 3500 PICKUP RAM 50 PICKUP SIERRA 1500 SIERRA 1500 CLASSIC SIERRA 2500 SIERRA 2500 HD SIERRA 2500 HD CLASSIC SIERRA 3500 SIERRA 3500 CLASSIC SIERRA 3500 HD SIERRA C3 SIERRA DENALI SILVERADO 1500 SILVERADO 1500 CLASSIC SILVERADO 2500 SILVERADO 2500 HD SILVERADO 2500 HD CLASSIC SILVERADO 3500 SILVERADO 3500 CLASSIC SILVERADO 3500 HD T100 TUNDRA W100 PICKUP W150 PICKUP W200 PICKUP W250 PICKUP W350 PICKUP CLUB CAB CUSTOM DLX DLX EXC HYBRID LARAMIE LIMITED LS LT LTZ NEW BODY NEW BODY SUPER CAB OLD BODY OLD BODY SUPER CAB QUAD CAB SE SIERRA SIERRA XC SL SLE SLT SPORT SR5 SS ST SUPER CAB WS WT 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994 1995 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2.4L (144) 2.6L (156) 2.7L 3RZFE 2L (122) 3.4L 5VZFE 3.7L (225) 3.9L Magnum (239) 351 Windsor HO 3L (181) 4.1L (250) 4.2L Triton (256) 4.3L 90 Degree L35 Vortec (262) 4.3L 90 Degree LB4 Vortec (262) 4.3L 90 Degree LU3 Vortec (262) 4.6L Triton (281) 4.7L 2UZFE (285) 4.8L (292) 4.8L GEN III LR4 Vortec (294) 4.8L GEN IV Flex L20 Vortec (294) 4.8L GEN IV LY2 Vortec (294) 4.9L (300) 4.9L Bi-Fuel (300) 4.9L LPG (300) 4L 1GRFE 4L Diesel (243) 5.2L CNG Magnum (318) 5.2L Magnum (318) 5.2L Small Block (318) 5.3L GEN III Electric/Gas LM7 (323) 5.3L GEN III Electric/Gas LM7 (325) 5.3L GEN III Flex L59 Vortec (323) 5.3L GEN III Flex L59 Vortec (325) 5.3L GEN III L33 Vortec (323) 5.3L GEN III L33 Vortec (325) 5.3L GEN III LM7 Vortec (323) 5.3L GEN III LM7 Vortec (325) 5.3L GEN IV Flex LC9 Vortec (325) 5.3L GEN IV Flex LMG Vortec (325) 5.3L GEN IV LH6 Vortec (325) 5.3L GEN IV LY5 Vortec (325) 5.4L Triton (330) 5.4L Triton Bi-Fuel (5.4L) 5.4L Triton CNG (330) 5.7L Chevy Small Block CNG (350) 5.7L Chevy Small Block TBI (350) 5.7L Chevy Small Block VIN L (350) 5.7L Chevy Small Block VIN M (350) 5.7L GEN 1 CNG L31 (350) 5.7L GEN 1 L31 Vortec (350) 5.8L 351 5.8L 351 Windsor 5.9L Cummins Turbo Diesel 12V (359) 5.9L Cummins Turbo Diesel 24V (359) 5.9L Cummins Turbo Diesel 24V HO (359) 5.9L Magnum (360) 5.9L Magnum HD (360) 5.9L Small Block (360) 5L (302) 5L Chevy Small Block (305) 5L GEN 1 L30 Vortec (305) 6.2L Diesel LH6 (379) 6.2L Diesel LL4 (379) 6.2L Flex L9H (376) 6.5L Diesel L49 (395) 6.5L Turbocharge Diesel L56 (395) 6.5L Turbocharge Diesel L65 (395) 6.6L (400) 6.6L Big Block (400) 6.6L Duramax Turbo Diesel LB7 (400) 6.6L Duramax Turbo Diesel LBZ (400) 6.6L Duramax Turbo Diesel LGH (400) 6.6L Duramax Turbo Diesel LLY (400) 6.6L D
Poison Spyder Rocker Knocker with Slider Pair, Bare Steel
Drilling requiredThe side mounted body bushing must be shortened by 3/16" to accomodate the rocker Poison Spyder Rocker Knocker with Slider Pair, Bare Steel Fits: 1987-1995 Jeep Wrangler YJ Product Information: Poison Spyder Rocker Knockers are the ultimate protection for your Jeep's vulnerable rocker panel area. As the trails get tougher and recreational off-roading gets more and more hardcore, vehicle body damage becomes more prevalent. And rocker panels are most vulnerable, taking hits from both underneath and the sides as you work your way through tight obstacles. Poison Spyder Rocker Knockers protect your rocker panels by cladding them in rugged, high strength 3/16" plate steel armor. Rocker Knockers are manufactured to hug the lines of your Jeep's rocker panels perfectly, forming a glove-fit with virtually no loss of valuable ground clearance. Specifically engineered for most Jeep CJ, YJ, TJ and LJ models, Rocker Knockers are CNC laser cut from high strength 3/16" plate steel, and precisiion brake-formed for a perfect fit. Bolt holes are countersunk for the included stainless steel flat head hardware, which yields a flat, unobstructed surface to slide over obstacles. All mounting hardware is included as well as detailed installation instructions. Poison Spyder Rocker Knockers bolt to your Jeep's body in key areas, and interface with strenghtened areas of the underside of the tub such as body mounts, strenthening ribs, etc. Because they mount to the body itself, there is no resulting gap or misalignment when a body lift is installed. For added side protection on the trail, these Rocker Knockers come with a tubular Slider. The Slider is crafted of high strength DOM structural tubing, welded to the Rocker Knocker with additional DOM tube spacers. The result is a combination of rocker panel protection and a tubular slider to keep your rig's bodysides a few precious inches away from taller rocks and trees. The Slider may also become an integral part of your driving strategy, as it may be useful to pivot the vehicle around obstacles while searching for traction. It also serves as a short entry step, assisting entry and egress. Years Covered: 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 and 1995
Warn ZEON 10 Winch 10,000 lbs Pulling Capacity, 12v DC Fits: Universal Product Overview: Choose your way to conquer the terrain. The ZEON 10 is tough enough to tackle anything you will, with a look that is advanced, capable and strong. Muck-busting sealing keeps out everything but the good times. Add a hyper-durable cast-aluminum housing, satin-black finish, and 10,000 lbs. single-line pulling capacity and, well, you've got a workhorse unit you can trust for years to come. Product Details: 10,000 lb. (4536 kg) single-line pulling capacity. Includes 80' of 3/8" galvanized steel wire rope Convertible control pack can be attached to the winch or remotely mounted, allowing for various winch mounting options and looks. (Relocation kit required and sold separately*) New-design planetary gear train and series-wound motor deliver fast, quiet, and reliable pulling power Satin-black powder-coated finish with stainless steel fasteners and clutch lever looks great and inhibits corrosion. Improved winch sealing to keep the elements out. Large diameter winch drum reduces rope wear, is light weight, and has an integrated rope anchor for easy rope installation. Backed by the WARN Limited Lifetime Warranty *Control Pack Relocation Kit. Required to mount control box remotely from winch. Part #: 89970 (Short kit), Part #: 89960 (Long kit) ZEON 8-S SPECS/PART NUMBER Part number: 88990 Rated line pull: 10,000 lbs. (4536 kg) single-line Motor: 12V DC, series wound Electrical controls: Contactor Remote Control: Remote switch, 12' (3.7m) lead Geartrain: 3-stage planetary Gear ratio: 216:1 Clutch (freespooling): Rotating ring gear Brake: Automatic mechanical cone Drum diameter/Length: 3.15"/9.0" (80mm/229mm) Weight (kit shipping): 98 lbs. (44 kg) Rope: 3/8" x 80' (9.52mm x 24.38m) steel Fairlead: Roller
Poison Spyder Rocker Knockers with Sliders,Bare Metal, Pair
Drilling requiredThe side mounted body bushing must be shortened by 3/16" to accomodate the rocker Poison Spyder Rocker Knockers with Sliders,Bare Metal, Pair Fits: 1976-1983 Jeep CJ5 Product Overview: Poison Spyder Rocker Knockers are the ultimate protection for your Jeep's vulnerable rocker panel area. As the trails get tougher and recreational off-roading gets more and more hardcore, vehicle body damage becomes more prevalent. And rocker panels are most vulnerable, taking hits from both underneath and the sides as you work your way through tight obstacles. Poison Spyder Rocker Knockers protect your rocker panels by cladding them in rugged, high strength 3/16" plate steel armor. Rocker Knockers are manufactured to hug the lines of your Jeep's rocker panels perfectly, forming a glove-fit with virtually no loss of valuable ground clearance. Specifically engineered for most Jeep CJ models, Rocker Knockers are CNC laser cut from high strength 3/16" plate steel, and precisiion brake-formed for a perfect fit. Bolt holes are countersunk for the included stainless steel flat head hardware, which yields a flat, unobstructed surface to slide over obstacles. All mounting hardware is included as well as detailed installation instructions. Poison Spyder Rocker Knockers bolt to your Jeep's body in key areas, and interface with strenghtened areas of the underside of the tub such as body mounts, strengthening ribs, etc. Because they mount to the body itself, there is no resulting gap or misalignment when a body lift is installed. For added side protection on the trail, these Rocker Knockers come with a tubular Slider. The Slider is crafted of high strength DOM structural tubing, welded to the Rocker Knocker with additional DOM tube spacers. The result is a combination of rocker panel protection and a tubular slider to keep your rig's bodysides a few precious inches away from taller rocks and trees. The Slider may also become an integral part of your driving strategy, as it may be useful to pivot the vehicle around obstacles while searching for traction. It also serves as a short entry step, assisting entry and egress. Years Covered: 1976, 1977, 1978, 1979, 1980, 1981, 1982 and 1983
Professional detailers know that time is money and the secret to a mile-deep shine is surface prep. The Detailer's Speedy Surface Prep Combo gives you the ability to decontaminate paint in record time with minimal effort so you can spend more time making money. Professional detailers are not the only ones who can take advantage of this amazing technology, enthusiasts will love the Speedy Surface Prep Towel's fast use and long lasting, washable design. The Detailer's Speedy Surface Prep Combo includes: Speedy Surface Prep Towel - Fine Grade The Speedy Surface Prep Towel is a soft microfiber towel coated with advanced polymerized rubber technology that works like detailing clay. It quickly removes bonded contamination. Bonded contamination is anything that remains on the surface after your paint has been washes. Rail dust, paint over spray, brake dust, industrial pollution and environmental fall out adhere to the paint's surface. This contamination reduces shine by creating a film on the paint and lessens your wax or paint sealant's ability to bond to. Detailer's Universal Clay Lubricant, 32 oz. Detailer's Universal Clay Lubricant works well with all styles and forms of detailing clay including the Speedy Surface Prep Towel. This VOC compliant lubricant spray contains no gloss agents so you can see and feel the true results of the Speedy Surface Prep Towel. Mist the surface with Detailer's Universal Clay Lubricant and wipe the Speedy Surface Prep towel, rubber side down, across the surface. As your work the towel across the surface you will feel it become smooth. Spray, wipe, and work a section at a time until your entire vehicle has a smooth as glass feel. If the Speedy Prep Towel becomes laden with contaminants, simply hose off and keep going. If you drop it on the ground, rinse away the grit, and continue using. We have heard reports of customers using the Speedy Prep Towel on 100 or more cars! Compared to detailing clay the Speedy Surface Prep Towel will last much longer, up to 100 vehicles. It is also washable and reusable. This is a professional towel that offers fast removal of surface contamination. It may require subsequent light polishing on softer paint finishes. Always test an inconspicuous spot first. Safe to use on paint, glass, molding, plastic, and metal finishes. Get professional results in record time with the Detailer's Speedy Surface Prep Combo! Contents: Speedy Surface Prep Towel - Fine Grade 32 oz. Detailer's Universal Clay Lubricant w/ trigger sprayer. A total retail value of $74.98. Save $9.99!
Pace Edwards BedLocker Explorer Series Tonneau Cover Kit BE011329 Tonneau Cover
Bedlocker Explorer Series Tonneau Cover Kit Fits 78.0 in./6 ft. 6 in. Bed ;Type: Hard Electric Retracting Tonneau; Installation Time: 1 hr;Mounting System: No-drill, clamp-in design (on most applications) for installation in about an hour; Material: Aluminum panels; Locking System: Utilizes Electric Motor and Factory tailgate lock; Fits over 5th wheel trailer hitches; Manual Switch Kit (available as an option) can be mounted in the cab or back by the tailgate in case of lost or broken remotes.;Electromagnetic brake locks cover in any position; Electric motor operated by remote control CHEVROLET GMC C10 PICKUP C15 PICKUP C15/C1500 PICKUP C1500 PICKUP C20 PICKUP C25/C2500 PICKUP C30 PICKUP C35/C3500 PICKUP K10 PICKUP K15 PICKUP K15/K1500 PICKUP K1500 PICKUP K20 PICKUP K25/K2500 PICKUP K30 PICKUP K35/K3500 PICKUP R10 PICKUP R1500 PICKUP V10 PICKUP V1500 PICKUP BIG TEN 1967 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 3.8L (230) 4.1L (250) 4.3L 90 Degree LB4 Vortec (262) 4.6L Chevy Small Block (283) 4.8L (292) 4.8L LPG (292) 5.4L Chevy Small Block (327) 5.7L Buick Small Block (350) 5.7L Chevy Small Block (350) 5.7L Chevy Small Block 4 BBL (350) 5.7L Chevy Small Block Car 2 BBL (350) 5.7L Chevy Small Block LPG (350) 5.7L Chevy Small Block TBI (350) 5.7L Chevy Small Block Truck 2 BBL (350) 5.7L Chevy Small Block VIN L (350) 5.7L Chevy Small Block VIN M (350) 5.7L Chevy Small Block VIN P (350) 5.7L Chevy Small Block VIN Y (350) 5.7L Diesel (350) 5L Chevy Small Block (305) 5L Chevy Small Block (307) 5L Chevy Small Block L69 (305) 5L V6 (305) 6.2L Diesel LH6 (379) 6.2L Diesel LL4 (379) 6.5L Chevy Big Block (396) 6.6L Chevy Big Block (402) 6.6L Chevy Small Block (400) 7.4L Chevy Big Block (454) DIESEL GAS LPG Pace Edwards BedLocker Explorer Series Tonneau Cover Kit BE011329 Tonneau Cover
Poison Spyder Body Armor Pair, Bare Steel
**Drilling required** Poison Spyder Body Armor Pair, Bare Steel Fits: 2007-2013 Jeep Wrangler Unlimited JK 4 Door Product Information: Poison Spyder Jeep Wrangler Unlimited JK Body Armor is recommended equipment for any Jeep Wrangler Unlimited JK venturing into off road situations where body damage is eminent. Jeep Wrangler Unlimited JK Body Armor protects the thin factory sheetmetal with rugged, precision-fit 3/16" plate steel or aluminum. Used by itself, Jeep Wrangler Unlimited JK Body Armor hugs the Jeep's body contours to provide protection with no loss of ground clearance. Used with the factory Rubicon rocker rails, the JK Body Armor helps prevent trail damage that can be caused by rocks pushing the factory rocker rails up into the body. And used with Poison Spyder's Jeep Wrangler Unlimited JK Rocker Knockers, the Jeep Wrangler Unlimited JK Body Armor provides one more line of defense for your JK, in the most complete, strongest, best looking package of rocker panel protection gear available for the Jeep Wrangler Unlimited JK. JK Body Armor is manufactured from either 3/16" high pressure steel plate or 3/16" 6061-T6 aluminum plate. Steel is preferred where the Jeep Wrangler Unlimited JK Body Armor will be installed by itself, without Rocker Knockers or other rocker panel protection. Aluminum is recommended where Rocker Knockers, the stock Rubicon rocker rails or other rocker panel protection will also be used. The aluminum pieces are much lighter weight (27 lbs. lighter for the 4-door versions), yet still provide excellent load distribution characteristics when used as a secondary barrier in conjunction with external rocker rails. Both steel and aluminum versions may be painted or powdercoated prior to installation, but only the aluminum ones may be installed raw without any protective coating. They may also be polished or clear-coated at the installer's discretion. Both steel and aluminum parts are CNC-laser cut and precision brake-formed for a precise fit to the unique contours of the Jeep Wrangler Unlimited JK body. Bolt holes are countersunk, and stainless steel flat head cap screws are supplied for a clean, flush-surface installation. Drilling of the body is required for installation. Jeep Wrangler Unlimited JK Body Armor is available bare (unfinished) or with a durable black powder coat finish. When selecting the powder coat option, please allow an extra 5-10 business days for delivery. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
BLACKFIRE Wet Diamond Metal Acrylic Sealant protects all metal surfaces with a revolutionary combination of acrylic and Wet Diamond polymers that withstand heat and bond to metal surfaces ? perfect for auto use. BLACKFIRE creates an extremely slick finish that sheds water effortlessly, helping to prevent water spots. BLACKFIRE Wet Diamond Metal Acrylic Sealant prolongs the beauty of just-polished metals and maximizes the time between polishing. BLACKFIRE Wet Diamond Metal Acrylic Sealant is designed for protection of daily drivers and any metal surfaces that regularly come into contact with the elements. The coating minimizes maintenance and keeps metals looking good. BLACKFIRE Wet Diamond Metal Acrylic Sealant is a modified version of Wet Diamond All Finish Paint Protection, designed to protect polished bare metals like aluminum. It seals the finish under a protective, transparent, acrylic shield. This shield helps protect against the effects of weathering, salt air, pollution, bug remnants build-up, and UV deterioration. BLACKFIRE Wet Diamond Metal Acrylic Sealant is great for protecting billet aluminum, plated, anodized and/or clear coated wheels. The super-slippery finish resists brake dust bonding, which makes future cleaning easier. In moderate climates, one application will protect for six months. In climates of severe heat and UV, reapply every 4 months. Treated surfaces have a slippery feel and will sheet water (free-flowing water, nozzle off the hose). When water stops sheeting and starts to "puddle" it is time to reapply. Directions: BLACKFIRE Wet Diamond Metal Acrylic Sealant can be applied by hand or machine polisher. To apply by hand, use a nickel-size amount of product on a foam or microfiber applicator and apply a thin uniform layer. Reapply to the applicator as needed. Allow to dry to a haze and hand buff with a  microfiber towel. To apply by machine, use a polishing pad and low speed (600-1000 rpm on a rotary, speed 3-4 on a dual-action orbital) and spread a thin, uniform coat over the metal surface. Reapply to the pad as needed. Allow to dry to a haze and hand buff with a microfiber towel. 16 oz.
Poison Spyder Front Brawler Lite Bumper Bare Steel
Poison Spyder Front Brawler Lite Bumper Bare Steel Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler Unlimited JK Product Information: The Brawler Lite front bumper for JK is a "mid-width", high clearance bumper designed to combine hard core off-road performance with full features. This bumper is fabricated from 3/16" plate steel, CNC laser-cut and precision brake-formed into a low profile, high clearance design. The ends of the bumper extend far enough to protect the lower corner of the JK grille, but not far enough to hinder tire clearance or tire access to vertical obstacles. Unlike the Poison Spyder BFH series bumpers for JK, the Brawler Lite can be mounted without cutting or altering the Jeep's frame rails. The faceted design of the Brawler Lite provides the best ground clearance and approach angle possible in a bumper that doesn't require frame modifications. The factory "Crash Bar" may be left intact or removed for a sleek appearance and high clearance. If keeping the crash bar, we recommend adding the Brawler Lite Skid Plate (PS-1759030, sold separately), which conceals the crash bar and protects the electronic sway bar disconnect. The Brawler Lite features recessed buckets to mount the factory fog lamps, fully protecting them in deep tubular sockets with direct-fit mounting flanges. Another thoughtful feature are the conveniently placed loom mounting holes, for reinstalling the "Christmas tree" loom hangers of the factory fog lamp harness. Any winch with a standard 10" X 4.5" mounting pattern will bolt right on to the Brawler Lite. Beefy internal gusseting directly below the winch mount provides the strength to sustain long, heavy pulls. The center of the bumper, where the winch sits, is slightly recessed with the winch mounting on top, without compromising the structural integrity of the bumper by cutting a huge hole in the bumper structure to place the winch down inside like other manufacturer's bumpers. If mounting a winch, you'll need a Winch Fairlead Mount PS-1759010, sold separately. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Poison Spyder Rear Crusher Corners Pair with LED Taillights and Back Up Lights Cutouts
Price: 605.99
**Drilling required** Poison Spyder Rear Crusher Corners Pair with LED Taillights and Back Up Lights Cutouts Fits: 2007-2013 Jeep Wrangler Unlimited JK Product Information: Poison Spyder Crusher Corners for the Jeep Wrangler Unlimited JK provide ultimate protection for the vulnerable rear corners of your Jeep Wrangler Unlimited JK. Crusher Corners are full-corner protectors, extending from the rear tailgate, around the side, over the wheel openings and all the way to the door openings. Made of rugged 1/8" steel, Jeep Wrangler Unlimited JK Crusher Corners may be used with the stock Jeep Wrangler Unlimited JK fender flares or with Poison Spyder's Jeep Wrangler Unlimited JK Rear Crusher Flares for the ultimate combination of rear corner armor. Poison Spyder Jeep Wrangler Unlimited JK Crusher Corners are unique among aftermarket corner armor, in that they provide full coverage while conforming to the compound curves and subtle contours of the Jeep Wrangler Unlimited JK body lines. Competitors' full corner protectors are brake-formed from flat steel, and may require the removal of large swaths of the stock sheetmetal in order to install them. Poison Spyder Crusher Corners are tool-formed to match the Jeep Wrangler Unlimited JK body lines in a close-fitting overlay, requiring no cutting of the body except to clearance for the flush-mount LED lights (on LED-ready versions). Jeep Wrangler Unlimited JK Crusher Corners come in a complete kit with stainless steel button head hardware. Drilling is required, as is installation of threaded "nut-serts" (Poison Spyder provides the nut-serts, a simple nut-sert installation tool and detailed instructions). Jeep Wrangler Unlimited JK Crusher Corners are shipped as bare steel. Jeep Wrangler Unlimited JK Crusher Corners are available with several taillight provisions: Blank has no taillight cutouts, for those doing custom fabrication; LED for use with a flush mount 4" high intensity LED taillight (PS-4104050); and for LED Taillights (PS-4104036) and Backup Lights (PS-4104300). When installing LED taillights in the Jeep Wrangler Unlimited JK, we recommend using the LED Resistor Kits (PS-4104650) sold separately. These will correct the current in your Jeep Wrangler Unlimited JK's electrical system for proper functioning of the LED's. They are sold by each, two are needed for one Jeep. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Poison Spyder, Ricochet Rockers, Bare Metal, Stock Wheel Opening, (Pair)
**Drilling required and the side mounted body bushing must be shortened by 3/16" to accomodate the rocker** Poison Spyder, Ricochet Rockers, Bare Metal, Stock Wheel Opening, (Pair) Fits: 1987-1995 Jeep Wrangler YJ Product Information: Poison Spyder Ricochet Rockers are built with the same hardcore toughness as its counterpart the Rocker Knocker, with the added utility of a combination 5" step and slider. This rocker protection is the pinnacle of hardcore body armor protection, style and convenience. The Ricochet Rocker is available for Jeep TJ, Unlimited, YJ, CJ7 and CJ8. Ricochet Rocker protection can be used alone or in combination with Crusher Corners. The two body armor pieces fit together at the rear flare area. Used together, Ricochet Rockers' and Crusher Corners form the ultimate protection, guarding your Jeep's body from the front wheel well to the tailgate. Ricochet Rockers are secured with counter sunk 3/8" stainless hardware, supplied in the kit with detailed installation instructions. Ricochet Rockers have a distinguishing 5" dimpled plate that acts as a step and a stout reinforcement for the slider. This makes the Ricochet Rocker protection a very effective armor addition and an effective pivot for getting into your rock chariot. Jeep TJ,YJ and CJ7 have three dimples, Unlimited and CJ8 have four. With the dimple protrusions pointing upward, they give the extra benefit of increased foot traction when entering or exiting the vehicle, even with boots covered with snow or mud. Ricochet Rockers are further reinforced with additional bracing below the dimpled step. The dual tube support and slider bar is constructed of 1.5" DOM tubing, the step and corner gussets are CNC laser cut from 3/16" steel plate, and brake-formed to act as their own gusset for strength and a clean appearance. Everything is professionally welded and comes to you ready to paint and bolt on. For installations in which you would like to protect the paint underneath the Ricochet Rocker, as well as provide a measure of vibration absorption, we offer an optional Rubber Liner, precisely cut to fit between the Rocker Knocker and the Jeep's body. Be sure to order these separately, as they're not included in the standard Ricochet Rocker package. Jeep Years Covered: 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 and 1995
Poison Spyder Body Armor Pair, Bare Aluminum
**Drilling required** Poison Spyder Body Armor Pair, Bare Aluminum Fits: 2007-2013 Jeep Wrangler Unlimited JK 4 Door Product Information: Poison Spyder Jeep Wrangler Unlimited JK Body Armor is recommended equipment for any Jeep Wrangler Unlimited JK venturing into off road situations where body damage is eminent. Jeep Wrangler Unlimited JK Body Armor protects the thin factory sheetmetal with rugged, precision-fit 3/16" plate steel or aluminum. Used by itself, Jeep Wrangler Unlimited JK Body Armor hugs the Jeep's body contours to provide protection with no loss of ground clearance. Used with the factory Rubicon rocker rails, the Jeep Wrangler Unlimited JK Body Armor helps prevent trail damage that can be caused by rocks pushing the factory rocker rails up into the body. And used with Poison Spyder's Jeep Wrangler Unlimited JK Rocker Knockers, the Jeep Wrangler Unlimited JK Body Armor provides one more line of defense for your Jeep Wrangler Unlimited JK, in the most complete, strongest, best looking package of rocker panel protection gear available for the Jeep Wrangler Unlimited JK. Jeep Wrangler Unlimited JK Body Armor is manufactured from either 3/16" high pressure steel plate or 3/16" 6061-T6 aluminum plate. Steel is preferred where the Jeep Wrangler Unlimited JK Body Armor will be installed by itself, without Rocker Knockers or other rocker panel protection. Aluminum is recommended where Rocker Knockers, the stock Rubicon rocker rails or other rocker panel protection will also be used. The aluminum pieces are much lighter weight (27 lbs. lighter for the 4-door versions), yet still provide excellent load distribution characteristics when used as a secondary barrier in conjunction with external rocker rails. Both steel and aluminum versions may be painted or powdercoated prior to installation, but only the aluminum ones may be installed raw without any protective coating. They may also be polished or clear-coated at the installer's discretion. Both steel and aluminum parts are CNC-laser cut and precision brake-formed for a precise fit to the unique contours of the Jeep Wrangler Unlimited JK body. Bolt holes are countersunk, and stainless steel flat head cap screws are supplied for a clean, flush-surface installation. Drilling of the body is required for installation. Jeep Wrangler Unlimited JK Body Armor is available bare (unfinished) or with a durable black powder coat finish. When selecting the powder coat option, please allow an extra 5-10 business days for delivery. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Poison Spyder Rocker Knocker with Slider, Bare Metal, Pair
Poison Spyder Rocker Knocker with Slider, Bare Metal, Pair Fits: 1976-1986 Jeep CJ7 Special Note: Drilling required and the side mounted body bushing must be shortened by 3/16" to accomodate the rocker. Product Overview: Poison Spyder Rocker Knockers are the ultimate protection for your Jeep's vulnerable rocker panel area. As the trails get tougher and recreational off-roading gets more and more hardcore, vehicle body damage becomes more prevalent. And rocker panels are most vulnerable, taking hits from both underneath and the sides as you work your way through tight obstacles. Poison Spyder Rocker Knockers protect your rocker panels by cladding them in rugged, high strength 3/16" plate steel armor. Rocker Knockers are manufactured to hug the lines of your Jeep's rocker panels perfectly, forming a glove-fit with virtually no loss of valuable ground clearance. Specifically engineered for most Jeep CJ models, Rocker Knockers are CNC laser cut from high strength 3/16" plate steel, and precisiion brake-formed for a perfect fit. Bolt holes are countersunk for the included stainless steel flat head hardware, which yields a flat, unobstructed surface to slide over obstacles. All mounting hardware is included as well as detailed installation instructions. Poison Spyder Rocker Knockers bolt to your Jeep's body in key areas, and interface with strenghtened areas of the underside of the tub such as body mounts, strenthening ribs, etc. Because they mount to the body itself, there is no resulting gap or misalignment when a body lift is installed. For added side protection on the trail, these Rocker Knockers come with a tubular Slider. The Slider is crafted of high strength DOM structural tubing, welded to the Rocker Knocker with additional DOM tube spacers. The result is a combination of rocker panel protection and a tubular slider to keep your rig's bodysides a few precious inches away from taller rocks and trees. The Slider may also become an integral part of your driving strategy, as it may be useful to pivot the vehicle around obstacles while searching for traction. It also serves as a short entry step, assisting entry and egress. Years Covered: 1976, 1977, 1978, 1979, 1980, 1981, 1982, 1983, 1984, 1985 and 1986
Seal in the mirror-like shine on all polished metals. Once you?ve achieved a mirror-like gloss, seal and protect polished metal surfaces with Wolfgang MetallWerkâ„¢ Concours Metal Sealant. This acrylic metal sealant eliminates any remaining polish residue for a cleaner, clearer shine that is protected from the elements. Aluminum naturally oxidizes when introduced to air. A light layer of oxidation actually protects the underlying metal from further oxidation. When you remove this layer, you have exposed the aluminum to the air again. Wolfgang MetallWerkâ„¢ Concours Metal Sealant replaces this barrier with clear acrylic polymers. This metal sealant provides durable protection against oxidation while the shiny, polished aluminum shows through. Wolfgang MetallWerkâ„¢ products will bring back life and luster to all your metal. Wolfgang MetallWerkâ„¢ Concours Metal Sealant is the ultimate high gloss, all metal sealant. The water-based, acrylic formula is completely safe and nonabrasive on all types of metal: clear coated, painted, anodized, polished, and bare metals. The finish is crystal clear ? never cloudy ? on wheels, diamond plate, bumpers, trim, trailers, and much more. Wolfgang MetallWerkâ„¢ Concours Metal Sealant locks in the shine you?ve created with Wolfgang MetallWerk metal polishes. Wolfgang MetallWerkâ„¢ Concours Metal Sealant goes a step beyond protection by removing any light residue that may detract from the metal?s shine. A light cleaning agent lifts any remaining residue from the metal as it deposits a clear layer of polymer protection. Metal polishing can be a messy process, creating a lot of black residue. Wolfgang MetallWerkâ„¢ Concours Metal Sealant removes the last remnants of this residue to reveal the cleanest, most reflective finish. Wolfgang MetallWerkâ„¢ Concours Metal Sealant is a must for daily drivers and trailers, anything regularly exposed to the elements. A brilliant shine can diminish in a short time without protection. Wolfgang MetallWerkâ„¢ Concours Metal Sealant leaves a slick coating that resists brake dust adhesion and repels dirt to maintain the just-polished gleam. You can expect 4-6 months of protection. When water no longer beads on the metal, it is time to reapply Wolfgang MetallWerkâ„¢ Concours Metal Sealant. Wolfgang MetallWerkâ„¢ Concours Metal Sealant is formulated specifically for metal surfaces. It should not be used on glass or plastics. Apply Wolfgang MetallWerkâ„¢ Concours Metal Sealant by hand or with a dual action or rotary polisher. Seal in the shine of just-polished metal with Wolfgang MetallWerkâ„¢ Concours Metal Sealant. Use a Lake Country CCS Gray Finishing Pad or a White UltraFine Polishing Pad by The Edge 2000 to apply Wolfgang MetallWerkâ„¢ Concours Metal Sealant. Set the maximum speed at 3-4 on a dual acti
UltraShine Aluminum 3 Inch round Side Steps Stainless Steel; Side Steps; Universal 3 in. Round; 2 Step Pads; 64 inchesSold as a pair CHEVROLET DODGE FORD GMC TOYOTA C1500 PICKUP C20 PICKUP C2500 PICKUP C30 PICKUP C3500 PICKUP D100 PICKUP D150 PICKUP D200 PICKUP D250 PICKUP D300 PICKUP D350 PICKUP F-100 PICKUP F-150 HERITAGE PICKUP F-150 PICKUP F-250 PICKUP F-350 PICKUP K1500 PICKUP K20 PICKUP K2500 PICKUP K30 PICKUP K3500 PICKUP RAM 1500 PICKUP RAM 2500 PICKUP RAM 3500 PICKUP RAM 50 PICKUP SIERRA 1500 SIERRA 1500 CLASSIC SIERRA 2500 SIERRA 2500 HD SIERRA 2500 HD CLASSIC SIERRA 3500 SIERRA 3500 CLASSIC SIERRA 3500 HD SIERRA C3 SIERRA DENALI SILVERADO 1500 SILVERADO 1500 CLASSIC SILVERADO 2500 SILVERADO 2500 HD SILVERADO 2500 HD CLASSIC SILVERADO 3500 SILVERADO 3500 CLASSIC SILVERADO 3500 HD T100 TUNDRA W100 PICKUP W150 PICKUP W200 PICKUP W250 PICKUP W350 PICKUP CLUB CAB CUSTOM DLX DLX EXC HYBRID LARAMIE LIMITED LS LT LTZ NEW BODY NEW BODY SUPER CAB OLD BODY OLD BODY SUPER CAB POWER WAGON QUAD CAB SE SIERRA SIERRA XC SL SLE SLT SPORT SR5 SRT10 SS ST SUPER CAB TRX4 WS WT 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 1992 1993 1994 1995 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2.4L (144) 2.6L (156) 2.7L 3RZFE 2L (122) 3.4L 5VZFE 3.7L (225) 3.7L Power-Tech (226) 3.9L Magnum (239) 351 Windsor HO 3L (181) 4.1L (250) 4.2L Triton (256) 4.3L 90 Degree L35 Vortec (262) 4.3L 90 Degree LB4 Vortec (262) 4.3L 90 Degree LU3 Vortec (262) 4.6L Triton (281) 4.7L 2UZFE (285) 4.7L Flex Power-Tech (285) 4.7L Power-Tech (285) 4.8L (292) 4.8L GEN III LR4 Vortec (294) 4.8L GEN IV Flex L20 Vortec (294) 4.8L GEN IV LY2 Vortec (294) 4.9L (300) 4.9L Bi-Fuel (300) 4.9L LPG (300) 4L 1GRFE 4L Diesel (243) 5.2L CNG Magnum (318) 5.2L Magnum (318) 5.2L Small Block (318) 5.3L GEN III Electric/Gas LM7 (323) 5.3L GEN III Electric/Gas LM7 (325) 5.3L GEN III Flex L59 Vortec (323) 5.3L GEN III Flex L59 Vortec (325) 5.3L GEN III L33 Vortec (323) 5.3L GEN III L33 Vortec (325) 5.3L GEN III LM7 Vortec (323) 5.3L GEN III LM7 Vortec (325) 5.3L GEN IV Flex LC9 Vortec (325) 5.3L GEN IV Flex LMG Vortec (325) 5.3L GEN IV LH6 Vortec (325) 5.3L GEN IV LY5 Vortec (325) 5.4L Triton (330) 5.4L Triton Bi-Fuel (5.4L) 5.4L Triton CNG (330) 5.7L Chevy Small Block CNG (350) 5.7L Chevy Small Block TBI (350) 5.7L Chevy Small Block VIN L (350) 5.7L Chevy Small Block VIN M (350) 5.7L GEN 1 CNG L31 (350) 5.7L GEN 1 L31 Vortec (350) 5.7L Hemi (345) 5.7L Hemi EZB (345) 5.8L 351 5.8L 351 Windsor 5.9L Cummins Turbo Diesel 12V (359) 5.9L Cummins Turbo Diesel 24V (359) 5.9L Cummins Turbo Diesel 24V HO (359) 5.9L Magnum (360) 5.9L Magnum HD (360) 5.9L Small Block (360) 5L (302) 5L Chevy Small Block (305) 5L GEN 1 L30 Vortec (305) 6.2L Diesel LH6 (379) 6.2L Diesel LL4 (379) 6.2L Flex L9H (376) 6.5L Diesel L49 (395) 6.5L Turbocharge Diesel L56 (395) 6.5L Turbocharge Diesel L65 (395) 6.6L (400) 6.6L Big Block (400) 6.6L Duramax Turbo Diese
Side Tube Steps by Dee Zee Universal;UltraBlack powder coat;3" round tube;2 step pads;64" lengthSold as a pair MITSUBISHI DODGE TOYOTA JEEP MAZDA ISUZU OLDSMOBILE FORD GMC HONDA MERCURY NISSAN CHEVROLET C30 PICKUP K25 PICKUP D250 PICKUP GRAND CHEROKEE (ZJ) R10 SUBURBAN W300 PICKUP D50 PICKUP XTERRA SIERRA 3500 R10 PICKUP V2500 SUBURBAN SILVERADO 2500 HD CJ7 GRAND CHEROKEE (WJ) EXPLORER SPORT F-150 HERITAGE PICKUP SIERRA 3500 HD PICKUP DURANGO TROOPER II BLAZER WRANGLER (97-06LJ) DAKOTA T100 RAM 1500 PICKUP F-250 SUPER DUTY PICKUP YUKON XL 1500 C25 PICKUP R1500 PICKUP D100 PICKUP MIGHTY MAX K15/K1500 SUBURBAN RAM 50 PICKUP TAHOE SIERRA 2500 HD K15 PICKUP FRONTIER C15/C1500 SUBURBAN PASSPORT WAGONEER V1500 SUBURBAN F-100 PICKUP C10 SUBURBAN R30 PICKUP K35 PICKUP K15 SUBURBAN NAVAJO RAM 5500 PICKUP K20 PICKUP F-150 PICKUP B2200 C15 SUBURBAN B3000 EXCURSION K3500 PICKUP B4000 MURANO V30 PICKUP RANGER BLAZER K5 C1500 SUBURBAN BRONCO II V20 SUBURBAN C25/C2500 PICKUP C35 PICKUP EXPEDITION HILUX TROOPER PILOT B2000 C3500 PICKUP RAM 3500 PICKUP OUTLANDER S10 SERIES BLAZER C20 SUBURBAN D350 PICKUP PICKUP D21 (HARD BODY) K10 SUBURBAN ASCENDER HOMBRE C1500 PICKUP AVALANCHE K15/K1500 PICKUP B2300 WRANGLER (87-95YJ) MONTERO W100 PICKUP C25 SUBURBAN R20 PICKUP V20 PICKUP ARMADA F-250 PICKUP B2500 V3500 PICKUP C10 PICKUP K20 SUBURBAN POWER RAM 50 V10 PICKUP S15 JIMMY SONOMA K25/K2500 PICKUP SILVERADO 1500 K30 PICKUP D200 PICKUP R1500 SUBURBAN EXPLORER F SUPER DUTY PICKUP B2600 RODEO S10 BLAZER W350 PICKUP R20 SUBURBAN R2500 SUBURBAN C35/C3500 PICKUP C20 PICKUP D300 PICKUP TUNDRA C2500 SUBURBAN GRAND WAGONEER AVALANCHE 1500 K2500 SUBURBAN F-350 PICKUP GRAND CHEROKEE (WK) YUKON SIERRA 1500 TACOMA MOUNTAINEER C2500 PICKUP S10 PICKUP WRANGLER (97-06TJ) K1500 SUBURBAN SILVERADO 3500 R2500 PICKUP SUBURBAN 2500 SILVERADO 3500 HD BRAVADA W200 PICKUP K25/K2500 SUBURBAN R3500 PICKUP ENDEAVOR C25/C2500 SUBURBAN F-150 LIGHTNING PICKUP V10 SUBURBAN K10 PICKUP W150 PICKUP C15/C1500 PICKUP CHEROKEE (XJ) SIERRA 2500 C15 PICKUP V2500 PICKUP EXPLORER SPORT TRAC RAM 4500 PICKUP RAM 2500 PICKUP D150 PICKUP V1500 PICKUP ELEMENT W250 PICKUP COMANCHE SILVERADO 2500 K35/K3500 PICKUP K1500 PICKUP SUBURBAN 1500 K25 SUBURBAN MONTERO SPORT K2500 PICKUP AVALANCHE 2500 PATHFINDER BRONCO S15 PICKUP JIMMY F-350 SUPER DUTY PICKUP YUKON XL 2500 Z66 FX4 SLE CLASSIC EDDIE BAUER SPECIAL EDITION DLX SAHARA LARAMIE EDGE 65TH ANNIVERSARY EDITION WS STX CONVENIENCE XLS X-RUNNER EL XLT EX PIONEER SL QUAD CAB SPX RS LIMITED FUNKMASTER FLEX EDITION LS 5.9 LIMITED SE NORMAL CAB X UNLIMITED LAREDO RUBICON SRT8 R/T XLT SPORT EL EDDIE BAUER SR5 CUSTOM CHIEF SIERRA XC ORVIS OLD BODY ROYAL ARMADA SE OFF-ROAD BRIARWOOD ONE-TON DLX PRE RUNNER DS WT NISMO OFF-ROAD SRT10 DENALI SWB RIO GRANDE ES TSI HYBRID BIG TEN PREMIER SC RENEGADE SHORT BED XE VALUE PACKAGE LWB ADVENTURER OVERLAND POWER WAGON Z71 NEW BODY ELIMINATOR SHELBY ST XL LX EV S EX-L SHT BD DLX EXC LTZ ONE-TON COUNTRY LTD LE SXT ISLANDER SPORT LUXURY DX
Skyjacker 4 Inch Lift Kit with Hydro Shocks C140CKS-H Complete Suspension Systems and Lift Kits
Price: 1526.89
Skyjacker 4 Inch Lift Kit with shocks 4 Inch Lift Kit with shocks;Lift Height: 4 inches;Front Lift: Leaf Springs ;Rear Lift: Rear Lift Blocks W/Add-A-Leaf ;Front & Rear Hydro Hydraulic Shocks W/ Shock Boots;Includes:Pitman Arm / Brake Line Extensions;Max Tire Size:35 X 12.5;Wheel Size:15-16 X CHEVROLET GMC C10 PICKUP C15/C1500 PICKUP C1500 PICKUP C20 PICKUP C25 PICKUP C25/C2500 PICKUP C2500 PICKUP C30 PICKUP C35 PICKUP C35/C3500 PICKUP C3500 PICKUP K10 PICKUP K15 PICKUP K15/K1500 PICKUP K1500 PICKUP K20 PICKUP K25 PICKUP K25/K2500 PICKUP K2500 PICKUP K30 PICKUP K35 PICKUP K35/K3500 PICKUP K3500 PICKUP R10 PICKUP R1500 PICKUP R20 PICKUP R2500 PICKUP R30 PICKUP R3500 PICKUP V10 PICKUP V1500 PICKUP V20 PICKUP V2500 PICKUP V30 PICKUP V3500 PICKUP BIG TEN SIERRA SIERRA XC 1967 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 3.8L (230) 4.1L (250) 4.3L 90 Degree LB4 Vortec (262) 4.6L Chevy Small Block (283) 4.8L (292) 4.8L LPG (292) 5.4L Chevy Small Block (327) 5.7L Buick Small Block (350) 5.7L Chevy Small Block (350) 5.7L Chevy Small Block 4 BBL (350) 5.7L Chevy Small Block Car 2 BBL (350) 5.7L Chevy Small Block LPG (350) 5.7L Chevy Small Block TBI (350) 5.7L Chevy Small Block Truck 2 BBL (350) 5.7L Chevy Small Block VIN L (350) 5.7L Chevy Small Block VIN M (350) 5.7L Chevy Small Block VIN P (350) 5.7L Chevy Small Block VIN Y (350) 5.7L Diesel (350) 5L Chevy Small Block (305) 5L Chevy Small Block (307) 5L Chevy Small Block L69 (305) 5L V6 (305) 6.2L Diesel LH6 (379) 6.2L Diesel LL4 (379) 6.5L Chevy Big Block (396) 6.6L Chevy Big Block (402) 6.6L Chevy Small Block (400) 7.4L Chevy Big Block (454) 7.4L L19 (454) DIESEL GAS LPG with Shocks Included Skyjacker 4 Inch Lift Kit with Hydro Shocks C140CKS-H Complete Suspension Systems and Lift Kits
Poison Spyder Front Brawler Bumper Bare Steel
**TRUCK FREIGHT WILL APPLY** Poison Spyder Front Brawler Bumper Bare Steel Fits: 2007-2013 Jeep Wrangler JK 2007-2013 Jeep Wrangler JK Unlimited Product Information: Poison Spyder Customs RockBrawler is the bumper of choice for the wheeler who wants pure hardcore function coupled with a brawny attitude. The RockBrawler is fabricated from 3/16" high pressure steel plate, CNC laser cut and brake-formed for a precise fit. The Stinger is made of 1.75" X .120 wall DOM tubing, and extends inside the bumper shell to the inner braces for added strength. The two D-ring shackle mounts are CNC-machined from 1" plate steel to provide brute strength for the most demanding recovery operations. Speaking of recovery, the integrated winch mount accepts most major manufacturer's winches up to 15,000 lbs. capacity, including the innovative Warn PowerPlant with integrated air compressor. The winch fairlead plate is flawlessly integrated into the bumper design, and doubles as gusseting for the Stinger, complete with Poison Spyder's signature oval lightning holes. Recessed light mounts are provided for retention of the factory fog lamps or aftermarket off-road lamps of your choice, and protect each one in a deep well of cold hard steel. Another characteristic of the RockBrawler is its amazing tire clearance. The bumper has faceted ends that angle inward, giving your Jeep the ultimate in clearance for large tires, even under maximized suspension movement, and during full turn scenarios. The angled sillouhette of the bumper ends allow for this tire clearance while still protecting the lower corner of the Jeep's grille. The RockBrawler's removable lower cover has an integrated skid plate for protecting the front sway bar disconnect mechanism. Jeep JK models that are not equipped with the factory sway bar disconnect can still utilize this lower skid as added protection for the front end components. The fasteners for this cover/skid, as well as all external fasteners provided with the RockBrawler, are stainless steel flat-head cap screws for a flush surface and protection from the rocks. Jeep Years Covered: 2007, 2008, 2009, 2010, 2011, 2012 and 2013
Skyjacker 4 Inch Lift Kit with Nitro Shocks C140CKS-N Complete Suspension Systems and Lift Kits
Price: 1554.89
Skyjacker 4 Inch Lift Kit with shocks 4 Inch Lift Kit with shocks;Lift Height: 4 inches;Front Lift: Leaf Springs ;Rear Lift: Rear Lift Blocks W/Add-A-Leaf ;Front & Rear Nitro Gas Charged Shocks W/ Shock Boots;Includes:Pitman Arm / Brake Line Extensions;Max Tire Size:35 X 12.5;Wheel Size:15-16 CHEVROLET GMC C10 PICKUP C15/C1500 PICKUP C1500 PICKUP C20 PICKUP C25 PICKUP C25/C2500 PICKUP C2500 PICKUP C30 PICKUP C35 PICKUP C35/C3500 PICKUP C3500 PICKUP K10 PICKUP K15 PICKUP K15/K1500 PICKUP K1500 PICKUP K20 PICKUP K25 PICKUP K25/K2500 PICKUP K2500 PICKUP K30 PICKUP K35 PICKUP K35/K3500 PICKUP K3500 PICKUP R10 PICKUP R1500 PICKUP R20 PICKUP R2500 PICKUP R30 PICKUP R3500 PICKUP V10 PICKUP V1500 PICKUP V20 PICKUP V2500 PICKUP V30 PICKUP V3500 PICKUP BIG TEN SIERRA SIERRA XC 1967 1968 1969 1970 1971 1972 1973 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 1988 1989 1990 1991 3.8L (230) 4.1L (250) 4.3L 90 Degree LB4 Vortec (262) 4.6L Chevy Small Block (283) 4.8L (292) 4.8L LPG (292) 5.4L Chevy Small Block (327) 5.7L Buick Small Block (350) 5.7L Chevy Small Block (350) 5.7L Chevy Small Block 4 BBL (350) 5.7L Chevy Small Block Car 2 BBL (350) 5.7L Chevy Small Block LPG (350) 5.7L Chevy Small Block TBI (350) 5.7L Chevy Small Block Truck 2 BBL (350) 5.7L Chevy Small Block VIN L (350) 5.7L Chevy Small Block VIN M (350) 5.7L Chevy Small Block VIN P (350) 5.7L Chevy Small Block VIN Y (350) 5.7L Diesel (350) 5L Chevy Small Block (305) 5L Chevy Small Block (307) 5L Chevy Small Block L69 (305) 5L V6 (305) 6.2L Diesel LH6 (379) 6.2L Diesel LL4 (379) 6.5L Chevy Big Block (396) 6.6L Chevy Big Block (402) 6.6L Chevy Small Block (400) 7.4L Chevy Big Block (454) 7.4L L19 (454) DIESEL GAS LPG with Shocks Included Skyjacker 4 Inch Lift Kit with Nitro Shocks C140CKS-N Complete Suspension Systems and Lift Kits
ul{ list-style: none; } Detailed Applications Year Make Model Engine Application Note 1998 SUZUKI SIDEKICK: SPORT L4 - 1.8L (1840 CC): GAS: FI: N: 2 Front Right; 2-Door 1998 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; 2-Door 1998 SUZUKI SIDEKICK: JS L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; 2-Door 1997 SUZUKI SIDEKICK: SPORT L4 - 1.8L (1840 CC): GAS: FI: N: 2 Front Right; 2-Door 1997 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; 2-Door 1997 SUZUKI SIDEKICK: JS L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; 2-Door 1997 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: 6 Front Right; Exc. Master Cylinder Hose 1996 SUZUKI SIDEKICK: SPORT L4 - 1.8L (1840 CC): GAS: FI: N: 2 Front Right; 2-Door 1996 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; 2-Door 1996 SUZUKI SIDEKICK: JS L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; 2-Door 1996 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: 6 Front Right; Exc. Master Cylinder Hose 1995 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1995 SUZUKI SIDEKICK: JLX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1995 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: U Front Right; Exc. Master Cylinder Hose 1995 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: 6 Front Right; Exc. Master Cylinder Hose 1994 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1994 SUZUKI SIDEKICK: JLX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1994 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: U Front Right; Exc. Master Cylinder Hose 1994 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: 6 Front Right; Exc. Master Cylinder Hose 1993 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1993 SUZUKI SIDEKICK: JLX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1993 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: U Front Right; Exc. Master Cylinder Hose 1992 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1992 SUZUKI SIDEKICK: JS L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1992 SUZUKI SIDEKICK: JLX L4 - 1.6L (1590 CC): GAS: FI: N: 0 Front Right; Exc. Master Cylinder Hose 1992 GEO TRACKER L4 - 1.6L (98 CID): GAS: FI: N: U Front Right; Exc. Master Cylinder Hose 1991 SUZUKI SIDEKICK: JX L4 - 1.6L (1590 CC): GAS: FI: N: 0
Detox your vehicle?s paint! The Wolfgang Clay Combo gives you the means to completely clean the paint of all the dirt, grime, and pollution that is keeping you from achieving the shine you want. The combo includes a 4 oz. bar of Wolfgang Elastic Poly Clay and a 16 oz. Wolfgang Clay Lubricant. Clay works by removing anything that protrudes above the surface of the paint. Clay removes tar, industrial fallout, bird droppings, brake dust, tree sap, and overspray. These contaminants may not be obvious but they cause the paint to feel bumpy and to appear patchy. The uneven appearance of the paint is caused by a patch of contaminants causing an uneven reflection. Wolfgang Elastic Poly Clay and Wolfgang Clay Lubricant will remove these contaminants and leave the paint silky smooth. The Wolfgang Clay Combo includes: 200 gram Wolfgang Elastic Poly Clay Bar Wolfgang Elastic Poly Clay Bar removes hidden contaminants that washing leaves behind. Detailing clay deep cleans auto paint by removing microscopic, embedded debris that gradually harms the paint. Wolfgang Elastic Poly Clay Bar is a long-lasting, reusable, synthetic detailing clay bar that will leave your vehicle smooth, shiny, and unbelievably clean. This 100 gram clay bar can be used between 7-10 times on average. 16 oz. Wolfgang Clay Lubricant Wolfgang Clay Lubricant works hand in hand with Wolfgang Elastic Poly Clay to give your vehicle the cleanest possible finish. Wolfgang Clay Lubricant protects the paint during the detailing clay process with a super slippery layer of polymers and wetting agents. The clay glides easily without scratching. When you?re finished claying, use Wolfgang Clay Lubricant to wipe away any residue left by the clay. Wolfgang Clay Lubricant leaves no residue. 1 Cobra Microfiber Detailing Towel 16 x 16 inches Use these microfiber detailing cloths for drying, buffing, or as a finishing touch. Microfiber is designed to be light, strong, super-absorbent and quick drying. The fibers are non-abrasive, and are woven so tightly that it?s absolutely lint free and extremely durable. Unbelievably, these ultra-tough fibers are engineered to absorb seven times their weight in moisture. When using on windows, it produces a streak-free finish. The Wolfgang Clay Combo is an excellent value! The 200 gram clay bar can be cut in half; each 100 gram portion can clean 3-4 cars. The 16 oz. Clay Lubricant also goes a long way. One vehicle will only need to be clayed once or twice a year to maintain a slick, shiny finish. Always follow claying with a wax or sealant, such as Wolfgang Deep Gloss Paint Sealant 3.0. Combo includes: 200 gram Wolfgang Elastic Poly Clay Bar 16 oz. Wolfgang Clay Lubricant
The BLACKFIRE Poly Clay & Lubricant Combo takes out what daily driving puts into your paint - brake dust, industrial fallout, rail dust, bugs, and tar. No wax or paint sealant can fully protect your paint from tiny metal particles. That's where the BLACKFIRE Poly Clay & Lubricant Combo comes in. This kit will restore smooth, slick paint that is ready for a glossy coat of wax. Nothing gets your paint cleaner. The BLACKFIRE Poly Clay & Lubricant Combo includes: 200 gram BLACKFIRE Poly Clay Bar BLACKFIRE Poly Clay Bar is a premium, nonabrasive grade of detailing clay that works on all paint finishes, including clear coats. It is easy to work with and leaves almost no residue on the surface of the vehicle. Poly Clay does not dry out with age and does not decompose with repeated applications. BLACKFIRE Poly Clay Bar leaves auto paint feeling slick, clean, and silky. 20 oz. BLACKFIRE Clay Lubricant BLACKFIRE Clay Lubricant has a polymer rich formula allows clay to glide over the surface without sticking or scratching. The clay lubricant provides a slippery coating between the clay bar and the paint to protect the paint from grit picked up by the clay. Cleaners in BLACKFIRE Clay Lubricant remove clay residue as you work, keeping the paint cleaner. The lubricants condition synthetic clay bars to extend their usable life. 2 Supreme 530 Microfiber Towels, 16 x 16 inches No job is too big for the Supreme 530 Microfiber Towel! This ultra plush, ultra thick towel has a soft touch to pamper your vehicle as it buffs away waxes, polishes, and quick detailers or dries your vehicle to a spot-free shine. The unique blend of 75% polyester and 25% polyamide gives the towel a balance of softness and toughness to perform any detailing task. The Supreme 530 Microfiber Towel is made of heavy 530 g/m² microfiber. Nothing leaves paint as smooth and clean as detailing clay. Use the BLACKFIRE Poly Clay & Lubricant Combo. Directions: Mist a small area (2 sq. ft.) of the vehicle with BLACKFIRE Clay Lubricant and rub the clay bar over the surface. The clay will "grab" at first. Continue lightly rubbing the clay over the surface until it moves freely. When the bar moves freely, the surface is clean. Wipe off any residues with a towel and proceed to the next area. If clay residues resist easy wipe-off, re-mist the cleaned area with Clay Lubricant and wipe with a clean microfiber towel. Even stubborn residues will wipe off easily. Combo includes: 200 gram BLACKFIRE Poly Clay Bar 20 oz. BLACKFIRE Clay Lubricant 2 Supreme 530 Microfiber Towels, 16 x 16 inches A total retail value of $58.96. Save $13.96!
Full Traction 6" Long Arm Suspension System without Shocks Fits: 1984-2001 Jeep Cherokee XJ Special Notes: We recommend any of these Front & Rear SHOCKS A Driveshaft is required for the Jeep Cherokee XJ part # FTS24519 A Slip Yoke Eliminator is also required for the Jeep Cherokee XJ part # 18676.60 Fits up to 32"-33" tires with minor modification or 35" tall tires with aftermarket fender flares. Product Overview: Full tractions off-road race winning 6.0" Long Arm system for Jeep XJ models is a complete replacement suspension system. It utilizes 4 leading link front axle mounting for a true and correct caster curve throughout the entire range of linear wheel travel. Other systems using radius arms, medium length arms called "long arms" and the rest can't match its performance. For the rear axle, they offer a complete replacement leaf spring assembly. The result is performance unmatched by other systems in both on & off road wheel travel and axle articulation. This system offers hard core rockcrawling performance from a system that rides and steers BETTER than stock. Do you drive your XJ daily? You now can without compromised handling. You want tough? All components in this suspension system are built for maximum off road punishment. Full Traction constructs their lower leading control arm assemblies of 2" x .250" wall DOM tubing for serious rock dragging strength, and 1/4" plate laser crafted bracketry throughout. No welding required to install. Kit Benefits: Complete replacement system Quality laser components Exclusive long arm 4-link design New replacement rear leaf springs Improved handling & articulation Increased ground clearance Heavy Duty 2" x .250" wall control arms Teflon lined heim joints for quiet operation Greasable control arm bushings DOT approved brake lines Powdercoat finish and plated hardware JeepSpeed race legal Fully Bolt-on Years Covered: 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000 and 2001
