Plexus Plastic Cleaner, Polish and Protectant Pocket Spray
7.99
Plexus® Plastic Cleaner, Polish and Protectant is the most effective polish you can use for your car! Plexus® Plastic Cleaner, Polish and Protectant was developed for use in the aviation industry - specifically, for cleaning and protecting aircraft windshields. As plexus became more and more popular, people quickly discovered it could be used on a limitless variety of plastic surfaces. Since then, Plexus Plastic Cleaner, Polish and Protectant has continued to grow in popularity, and today it is recognized as the most effective plastic cleaner, protectant and polish on the market today. Until Plexus Plastic Cleaner, Polish and Protectant, plastic-cleaning products have proven less than satisfactory. Existing cleaners are often messy to use (especially creams and pastes) and require several steps to apply. They have to be rubbed on and buffed. They often leave a sticky, tacky or oily residue. And, in many cases, they're abrasive, leaving small lines in the plastic. Dissatisfied with these cleaners, many people resort to products that are alcohol, ammonia, or petroleum-based. Unfortunately, these products can dry out plastic, leading to cracking and discoloration over time. The bottom line: over the years, people have had no truly reliable, effective products to turn to for cleaning and protecting plastic. Fortunately, with Plexus Plastic Cleaner, Polish and Protectant there's a solution! Plexus Plastic Cleaner, Polish and Protectant is the most effective product available for cleaning, protecting, and polishing all kinds of plastic. Plexus Plastic Cleaner, Polish and Protectant is easier to use than ordinary cleaners. Its convenient aerosol applicator prevents dripping, leaking, evaporating, and coagulating at the tip of the nozzle (as is common with pumps and squeeze bottles). To use Plexus Plastic Cleaner, Polish and Protectant , simply spray and wipe - no buffing, no mess, and no waste. Plexus Plastic Cleaner, Polish and Protectant protects plastic more effectively than ordinary cleaners. Because Plexus Plastic Cleaner, Polish and Protectant seals the pores in plastic surfaces with a micro-thin layer of shiny, protective wax, plastic becomes resistant to debris, oil, scratches, and eventual yellowing. And its anti-static properties repel dust and lint. Plastic magnified. This illustration shows the surface of plastic, which is actually porous. By filling in these pores with a clear, micro-thin layer of wax, Plexus protects plastic like no other product. Since new plastic is most vulnerable to contaminants and damage, using Plexus Plastic Cleaner, Polish and Protectant early on can help in the long-term protection and maintenance of plastic. Plexus Plastic Cleaner, Polish and Protectant gives you a cleaner, more lustrous finish than ordinary cleaners. Plexus Plastic Cleaner, Polish and Protectant leaves no smears and no smudges. Instead, the finish it leaves is shiny, brilliant, and clear like no other
